Old 05-12-2015, 03:38 AM
Day2_69Z Day2_69Z is offline
Default Re: Well, the Chevelle is D.O.A.....
DOUG NASH
4 SPEED
or
5 Speed.... 4+1
TREMEC
Day Two Specialties /High Quality Muscle Car Parts.
Old 05-12-2015, 03:51 AM
VintageMusclecar's Avatar
Nope and nope.
Old 05-12-2015, 04:42 AM
Mopar A-833?
Jason
Old 05-12-2015, 11:50 AM
earntaz earntaz is offline
TreMec
Old 05-12-2015, 12:41 PM
novadude novadude is offline
I still don't understand this one. There must be thousands of Chevelles out there that have turned 4000 rpm in high gear (1:1) many times on stock driveshafts. Munice + 12-bolt = stock length shaft, right? The factory offered 4:10s which would put the driveshaft at that speed barely above legal posted speed limits. I wonder what was going on in your car that made it spit out the shaft?
Old 05-12-2015, 12:52 PM
Not a Mopar and not a Tremec.
I'll post up the details once it's here.
John, at this point all I can conclude is that the shaft was junk from the beginning. That still doesn't explain why the 2nd shaft also had a vibration (out of balance or warped also??), but at this point it's water under the bridge. All I can do is pick up the pieces (literally) and move forward.
Old 05-12-2015, 12:58 PM
napa68 napa68 is offline
You're killing me!
http://www.richmondgear.com/index.ph...t-5-speed-w-od
Old 05-12-2015, 01:00 PM
oooops
you already crossed out the Richmond
kan't reed weell
Old 05-12-2015, 01:12 PM
That was actually my first choice, but as per a call directly to Richmond yesterday, that box won't be available until July at the earliest.
Old 05-12-2015, 01:19 PM
68l30's Avatar
68l30 68l30 is offline
The part that confuses me...it came apart under no real load. At what RPM would this have failed on the ground with traction /weight and increase friction-resistance in the driveline ? It could have been much worse. How much depth was in the yoke engagement, how did it slip under rotation? Could there have been a bind adding stress to the shaft during torque / suspension cycling? Any clues on what's left of the Muncie or the shaft (tubing, wall thickness, cracks) itself?
I enjoy doing Destructive & NDT testing on Welded-Fabricated components here at work....I find all failures interesting as they each tell a story. I'm looking forward to seeing this back together !
BIG
