Old 03-12-2004, 11:26 PM
Baldy Baldy is offline
Default Inspection color's on driveshaft
Can someone tell me the inspection color's on a 69 Yenko driveshaft.No one in the St.Louis area seem's to know.
Thanks Baldy
Baldy Shockley
Old 03-13-2004, 02:27 AM
JChlupsa JChlupsa is offline
Default Re: Inspection color's on driveshaft
Pic from the WWMC site. I believe that Brain did this car if I am not mistaken.
http://www.worldwidemusclecars.com/s...5166/5166.html
Find the same pic above and click on the thumbnail to enlarge it :P
Old 03-13-2004, 10:20 AM
Kurt S Kurt S is offline
Auto or manual????
Kurt S - CRG
Old 03-13-2004, 10:45 AM
396L35's Avatar
396L35 396L35 is offline
Its a manual car Kurt. I thought you had that car done Jim??? Its a great looking ride, and I will see you next weekend at the show downtown. Mark
Mark
Old 03-14-2004, 05:34 AM
Kurt S
Thanks for the reply. The car is a 4 speed,69 Rally Green Yenko.I put on the inspection marks, but didn't have the one for the driveshaft. My buddy's 375HP 396 has two orange rings, but I don't think that is right for my car.
Thanks again.
Jim Shockley
Baldy Shockley
Old 03-14-2004, 05:37 AM
Mark you know that a car is never done. See you next weekend.
Baldy.
Baldy Shockley
Old 03-14-2004, 08:58 AM
I'm not the expert on markings, but so far I've only seen one driveshaft used on all manual trans cars (but I've only seen one broadcast sheet for a BB manual car and that box was hard to read). If so, then it's the same as a Z.
Auto's are different for sure.
Kurt S - CRG
Old 03-17-2004, 10:44 AM
Quick sanity check. Who has a known original driveshaft for a 69 BB 4 speed that we can measure the length to compare to a SB manual / powerglide part? I have the SB part.
Kurt S - CRG
Old 03-17-2004, 06:59 PM
:Kurt,
My driveshaft is from the front of the u-joint to the back of the other is 51 inches Hope this helps.>()---51---()<
Baldy Shockley
Baldy Shockley
Old 03-19-2004, 07:42 AM
Baldy,
How about we compare centerline of U-joint to centerline of U-joint (same as front edge to front edge)? A measurement others have used, easy to measure and for others to repeat.
My 2 driveshafts both measure 49 9/16 inches.
Kurt S - CRG
