Old 08-18-2019, 12:53 PM
napa68 napa68 is online now
Originally Posted by firstgenaddict View Post
I adjusted valves per JohnZ's specs last year and did the carb and idle today, it pulls 15" vacuum at 900 RPM, wow...
That made a big difference in my car as well!
Old 08-18-2019, 05:30 PM
TimG TimG is offline
The car looked great at Nationals. It is a beautiful LT1.
firstgenaddict (08-18-2019)
  #13
Old 08-18-2019, 07:45 PM
Thanks Tim I am quite satisfied with how the paint has turned out. It was SO dull and dry when I got it.
Here are a few before and after shots of some details where the paint was chipped.
Old 08-18-2019, 11:39 PM
earntaz earntaz is offline
I got my black 63' Corvette used in late 66' -- West Texas/Eastern NM car and the paint was just like this in many places after only three years of existence ... Blue Corral was the rage back then ... TAZ
Old 08-18-2019, 11:58 PM
Liberal application of Meguires number 7 with a foam applicator - allow to dry overnight - use a cotton diaper to remove film.
Repeat
Repeat once again.
Once the paint it hydrated and looks like actual an actual GM lacquer finish you can go about with the correction of chips, scratches, & other blemishes etc.
Go around the car with masking tape and mark every area which you will fill with touch up
preferably with another color tape mark any scratches, scuffs, anything other than color replacement.
Go around the areas which will not be touched up any scratched areas and use a fine cleaner or a swirl remover and hand polish on the scratch, (something which is very low on cutting) you want to shoot for approx 50% improvement in the scratch or scuff - from the up close perspective.
IF done selectively and addressed individually (vs machine buffing areas) a 50% improvement in scratches can easily be achieved without removing the fine lacquer surface texture while dramatically improving it's exterior presentation.
The Following 4 Users Say Thank You to firstgenaddict For This Useful Post:
markinnaples (08-19-2019), napa68 (08-20-2019), PeteLeathersac (08-19-2019), ScottG (08-19-2019)
  #16
Old 08-22-2019, 03:18 AM
73RSLTZ's Avatar
73RSLTZ 73RSLTZ is offline
Looks great Jag
The brother of the infamous firsthgen addict
1973 RS Type LT Z28 4spd
1973 L82 Black Corvette 4spd Original special order paint.
1997 Polo Green SS Camaro
2002 Electron Blue Z06(sold)
Old 03-28-2020, 09:44 PM
One from a few weeks ago... I was having coolant issues, had the fan clutch rebuilt a year ago, along with replacing the waterpump with the correct one and then in Sept -Oct I noticed a small coolant leak. I originally thought it was the radiator and was going to pull it and have a new core installed. I finally traced it to the water pump gasket on the pass side - apparently it was due to my faulty installation over a year ago.
Not a drip after pulling the water pump and putting in a set of NOS gaskets -
and a few photos from Today...
RPOLS3 (03-28-2020)
  #18
Old 03-28-2020, 10:17 PM
Steve Shauger's Avatar
Administrator
Nothing like taking them out and stretching their legs a bit. Great pics James!
www.yenko.net
www.vintagecertification.com
Old 03-28-2020, 10:51 PM
Zedder's Avatar
Zedder Zedder is online now
Lookin’ good!
Mark
1996 Carrera & 1993 Fat Boy
Old 03-29-2020, 12:29 AM
Good on you for taking her out. Woo hoo~~
