Old 03-26-2020, 05:31 AM
mssl72's Avatar
mssl72 mssl72 is offline
Man, you're just moving right along!!
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 03-27-2020, 07:44 PM
kwhizz kwhizz is offline
Well..... The car had a small block Chevy installed in it some time in it's past....When the frame mounts were welded in at that time it, ended up that the engine was off-center about 3/8" towards the drivers side......… Fast forward...… After installing the #605 box and grinding some clearance on it to clear the exhaust manifolds (seemed like a good idea and a simple fix at the time)…… Anyhow...… After moving on from that point, I noticed some fluid on the floor below the steering box but I wasn't too concerned at the time because after cutting the brake lines in that same area after removing the old braking system I thought it was brake fluid...… Wrong.... Darn..... So, after removing the box and looking closely at it I seen where the leak was coming from.... Ground a little too much off the box..... Double Darn !!!!…… So we get back to basics...… LOL..... I'm making some new mounts (Pic's to follow) to correct that issue which will remove the steering box clearance issue and center the engine...… This car stuff is hard sometimes...… Should have this corrected tomorrow Also.... The Rick's Tank showed up today.... They built it for this conversion as a passenger style tank as we requested and I will have to remove the spare tire well in the wagon to allow for it's installation...… More Fun...… LOL...…Got the old tank out...
The Following 6 Users Say Thank You to kwhizz For This Useful Post:
Arrowsmith (03-27-2020), dykstra (03-27-2020), PeteLeathersac (03-28-2020), SS427 (03-27-2020), Tenney (03-28-2020), Xplantdad (03-28-2020)
  #43
Old 03-28-2020, 05:06 AM
Damn Ken! If it’s any consolation, we appreciate the drama. I also appreciate your willingness to post the good, bad, and ugly. Is the box salvageable?
Thanks for taking the time to share,
Jason
Old 03-28-2020, 05:00 PM
bergy's Avatar
bergy bergy is offline
I haven’t commented yet - just enjoying the build. Ken - you always do such a great job!
Old 03-29-2020, 12:06 PM
Jason
New box ordered...…. Don't want to take a chance...… If it leaks.....Well.....
Old 03-29-2020, 12:36 PM
Made new mounts and welded them in...… The engine is now about 3/16 towards the passenger side, so I picked up a good 1/2" of clearance on the drivers side..... The new steering box (ordered) will have plenty of room without any clearance issues…. I also leveled the engine as it was down about 1/4" on the drivers side...… Now I can sleep at night.... LOL...… Still waiting for parts to complete the final needs of the engine compartment...…… Time to get rid of the spare tire well and get the new Gas Tank installed
The Following 4 Users Say Thank You to kwhizz For This Useful Post:
Arrowsmith (03-29-2020), dykstra (03-29-2020), RPOLS3 (03-29-2020), Xplantdad (03-29-2020)
  #47
Old 03-29-2020, 08:01 PM
Continuing with the process..... Not gonna miss some of this old sheet metal
The Following 2 Users Say Thank You to kwhizz For This Useful Post:
CC Rider (03-31-2020), dykstra (03-29-2020)
  #48
Old 03-30-2020, 06:41 PM
Started the day with a big hole in the floor where the spare tire well was....Got the rear mounts for the Rick's tank installed..... and got the tank installed..... And I have to make some new side mounts for the tank to get that part of the build finished up...….
The Following 3 Users Say Thank You to kwhizz For This Useful Post:
Arrowsmith (03-30-2020), dykstra (03-31-2020), Xplantdad (03-30-2020)
  #49
Old 03-30-2020, 09:15 PM
When we are finished we will fabricate a storage compartment above the gas tank...….. Also the power steering pump came in today so I got that all finished up along with the belt installation...…. I also got the front tank mounts fabricated..... Tomorrows project is to get them installed...…
Arrowsmith (03-30-2020), dykstra (03-31-2020), SS427 (04-02-2020), Xplantdad (03-30-2020)
  #50
Old 03-31-2020, 12:48 AM
KM265S KM265S is offline
You've been BUSY.
The Following User Says Thank You to KM265S For This Useful Post:
kwhizz (03-31-2020)
