Old 07-10-2006, 01:28 AM
sixpakjoe sixpakjoe is offline
Default 68 Z/28 Engine and Body Parts
1968 Z/28 302 engine cylinder head, part # 3917291, date code C-12-8, freshly machined, magnafluxed, surfaced, new 2: 02 Manley intake valves, 1: 60 Manley exhaust valves, new bronze wall guides, perfect circle oil seals, fresh multi-angle valve job, new correct spring pressure 302 Z/28 valve springs, retainers, and valve locks. Best of everything. $700
1968 Z/28 factory original exhaust manifolds. GM Part # 3872730 RH, date code D-7-8, and GM Part # 3892683 LH, date code D-10-8. Excellent condition with smog holes, all mounting bolts, and exhaust pipe flange nuts. Also spark plug heat shields included. $600 complete
Edelbrock graphite material exhaust gaskets, new in package. Never used. For small block Chevy with headers. $12
Chevrolet HP small block distributor, Part # 1111478, Date Code 2D18. Believed to be removed from Chevelle 327-325 HP engine. Excellent condition. Has been disassembled, bead blasted, shaft checked for straightness. Bushings are like-new condition. Includes Accel points and condenser kit, Part #101 GM (standard RPM kit with 23 oz springs), distributor cap and rotor kit Part #8124 (high performance kit with brass inserts), and Taylor Thunder Volt 8.2 mm factory replacement Ultra High Performance ignition wire set, Part # 84001, black color with 90 degree boots. All parts are brand new in original boxes. Distributor is in like new condition. $220 for everything.
Brand new ignition coil (#202 coil) for 1968 Z/28 302 engine. $100.
Center dash ashtray for 1967 or 1968 Camaro with black standard dashboard (not wood grain), Part # 1A26902. Restored to like-new original condition. $65
Small block Chevy fuel pump mounting bolts (2), new in package $8.
Complete set of correct intake manifold mounting bolts for Z/28 302 engine, new in package, never used. $15
Engine pull bracket kit for intake manifold (left bracket bolts to intake manifold, right bracket bolts to bell housing) for 1968 Corvette with small block engine. New in box -- never used. $15
Trico wiper arms (used, very good condition) and 14" Trico blades (brand new) for 1968 Camaro. $15
Original front license plate mounting bracket for 1968 Camaro, excellent condition, Part #AAC. $10
WILLING TO OFFER PACKAGE DEALS FOR MULTIPLE PURCHASES.
Shipping charges not included. Will send pictures to serious buyers. Contact Joe at 623-587-4978 or [email protected]
