Old 11-07-2018, 03:14 PM
Default 69 Camaro Four bumper bolts
Needing four of the correct bumper bolts that bolt the outer bumper brackets to the body.
The ones I have feature large captured washers. I believe the correct ones have small captured washers. Wouldn't go to this trouble, but the bumper is off right now. I finally got around to repainting my grill the correct silver color. The paint that was on there was too dark. Very pleased with the outcome. Will post pics in a separate thread.
Not asking for a handout. Glad to pay for the parts and shipping.
Attachments - The Supercar Registry bolts.3.jpg bolts.2jpg.jpg bolts.1.j[g.jpg 014.jpg
Old 11-11-2018, 10:17 AM
fiveforty fiveforty is offline
Did you ever get any bumper bolts. If you have a pic of what you need I most likely have some.
Old 11-11-2018, 04:23 PM
Default Which is correct?
I realize there could be several different manufacturers of bolts and therefore different head markings, so not really concerned about that. I have found multiple instances of different manuafacturers bolts used interchangeably.
However, I doubt that bolts with different size captured washers were used unterchangeably.
The smaller washer on these 3/8 bolts is 3/4 inch. The larger is 1 inch.
Which is correct for the outer bumber brackets? Talking about the four bolts that fasten the outer bumper bracket to the lower fender extension on a 69 Camaro.
I looked in the AIM and can't even find the page were the bumber gets bolted on.
Old 11-11-2018, 07:41 PM
These have been on the shelf for 41 years off a 1 owner car. looks like small washers.
Old 11-11-2018, 08:50 PM
That is what I thought.
Can anyone confirm? Again, I could not find bumper install in the AIM, other than VE3, and it simply states to use the "production" part. I just can't find a part number for the production part.
If confirmed, I need four of those bolts with the small captured washer, i.e. 3/4 inch o.d.
Old 11-11-2018, 09:08 PM
jl8z28 jl8z28 is offline
Are you talking about the one's that you can see on the outside of the body i looked at my 69 and they were the small washer
Old 11-11-2018, 09:12 PM
Mine has been through the legends judging so i would say they are correct
Old 11-11-2018, 09:45 PM
Yes, the ones you can see from underneath the front bumper. They go through the outer brackets that fiveforty posted.
I may have some in my stash pile, but if someone has a set reasonably priced, i would rather do that than go hunting. Just too much going on right now.
Old 11-12-2018, 03:51 PM
Enoch Enoch is offline
Originals have small washer but a pointed pinched tip. I have them by the bucket full :-) I have flying F head marking, e, and rbw I can post pictures if you like.
