#11
Yes, I would expect that to be the case as well, however the other factor to considered is causing distortion in the glass when looking through it. The polishing pads I used were 5 inch diameter (they do make 3 inch diameter) so I did not want to spend too much time in one particular spot.
Joe 1969 Camaro |
#12
I had a slight gouge in middle of a swath of scratches on the pass side of my original front glass I used a 3" felt pad flat against the surface to polish the entire glass after I used a dremel to SLOWLY smooth the depth of the scratch.
It is now only noticed if you look for it.
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
The Following User Says Thank You to firstgenaddict For This Useful Post: | ||
Z282NV (01-06-2022) |
