Old 04-22-2019, 09:40 PM
RALLY RALLY is offline
Default Used Original 69-Z28 Camaro Factory Fan Shroud 3938615
I have a used 1969 Camaro Z-28 Factory Fan Shroud to sell. Shroud GM number molded 3938615. This shroud came off my 69 Z-28. This fan shroud is not perfect. It has a crack on the bottom side, bottom of shroud was cut out some for trans lines when car was on the drag strip. Original fan shroud with correct GM numbers molded in. I believe this shroud can be fixed up to look good on your car. I will sell this shroud for 75.00 dollars and it still has the top mounting bracket left on the top also. Shipping will be 28.00 dollars. NOS stock shrouds like this sell for close to 300.00 dollars and good used one not damaged or modified are selling for 200.00 dollars. You can buy this for 75.00 dollars plus shipping. Send me your email address for pictures.
Old 04-23-2019, 08:18 PM
Price drop 35.00 dollars.
