Old 07-20-2019, 03:01 PM
Enoch Enoch is offline
Default THREAD CLOSED 400 + lbs of Restored hardware black and cad
THREAD CLOSED AS OF 9/10/19......all items were either sold or moved to other threads
Just got back from the platers about 400-plus pounds of original restored Hardware. We'll be putting together many more sets for various cars. Front end sheet metal kits, suspension kits, engine and drive line kits, as all the other ones have sold. Will be putting them together for Chevelles Camaros novas Impalas Corvettes GTOs etc etc. If there's any year specific car you're looking for hardware for whether it's an individual bolt or a complete kit let me know. Keep checking this thread as I will start post parts and pieces on it. Thanks SYC!
Attachments - The Supercar Registry 20190731_120018-1008x567.jpg 20190731_115921-1008x567.jpg 20190723_114201-567x1008.jpg 20190723_113836-1008x567.jpg
Old 07-20-2019, 05:11 PM
Hrlyfxdl's Avatar
Hrlyfxdl Hrlyfxdl is offline
Nice Rich, looking forward to it.
The Following User Says Thank You to Hrlyfxdl For This Useful Post:
Enoch (07-20-2019)
Old 07-20-2019, 08:25 PM
First up will be four different sets of 67 through 69 Camaro d80 front spoiler mounting hardware. All restored original pieces along with for NOS nuts.
Set 1 4 AF 10-24 bolts with recessed head and captured flat washer.
5/16-18 rbw head marking bolts pinched tip recessed head captured flat washer
4 5/16-18 Anchor head marking flat tip bolts with recessed head capture flat washer
And for 10/24 nuts 3/8 hex captured conical washer. Perfectly restored pieces. $90. Ppff
Old 07-20-2019, 10:17 PM
Restored original blower motor to outer heater box mounting bolts, P headmarking. $40 ppff
Old 07-21-2019, 12:03 AM
Set 2 and 3 of original restored 67 through 69 Camaro d80 front spoiler mounting hardware. All restored original pieces along with for NOS nuts.
2 5/16-18 rbw head marking bolts pinched tip recessed head captured flat washer
4 5/16-18 SEMS head marking flat tip bolts with recessed head capture flat washer
************SOLD************
Old 07-21-2019, 12:15 AM
4th set of original restored 67 through 69 Camaro d80 front spoiler mounting hardware. All restored original pieces along with for NOS nuts.
2 5/16-18 E head marking bolts pinched tip recessed head captured flat washer
Old 07-21-2019, 12:31 AM
Excellent original restored 10 and a half inch clutch starter bolts. Correct for Z28 L88 ZL1 and 67 and earlier small blocks.
Included are two c grade 8 starter mounting bolts
One flying F starter brace to block mounting bolt
1 NL head marking solenoid Shield to starter brace mounting bolt
And one flanged nut with e marking which mounts the starter brace to the starter. These are extremely nice. $60. Ppff (X)
***********SOLD ************
Old 07-21-2019, 12:39 AM
ZL2 Cowl induction hood solenoid and relay mounting hardware.
The AF head marking bolt attaches the solenoid to the flapper door bracket
And these RBW head marking bolt attaches the relay to the firewall. Excellent restored pieces. $35. Two sets available.
Old 07-21-2019, 12:48 AM
The Anchor head marking bolt attaches the solenoid to the flapper door bracket
And these ((D)) in circles head marking bolt attaches the relay to the firewall. Excellent restored pieces. $35.
Old 07-23-2019, 03:46 PM
Original restored battery hold down clamp mounting bolts. The two would the flat and enlarge washer are the early styles up until mid to late 69. The one with the smaller washer and pointed tip was introduced sometime late 68 69.
Sems
LF
S
$30 each ppff
