Old 10-02-2022, 05:40 PM
TFox07 TFox07 is offline
Default Big Block (COPO) Carburetor return spring
I have purchased a few of these springs. They're weak and won't put it back to idle. I've shortened them and still have the same problem. I can't imagine others haven't experienced the same issue. Any suggestions would be greatly appreciated.
Attachments - The Supercar Registry large-egp-1767.jpg A56ADCF7-5F6B-48B5-94E7-249E8160731B.jpeg
Old 10-02-2022, 09:09 PM
R68GTO R68GTO is offline
Along for the ride, I have the same issue with this spring.
Old 10-02-2022, 11:08 PM
Least I know I'm not alone. Thx for the reply.
Old 10-02-2022, 11:36 PM
luzl78 luzl78 is offline
I also am looking for a stronger spring.
Old 10-03-2022, 01:55 AM
68 DANA's Avatar
68 DANA 68 DANA is offline
I experienced the same issue. What options are out there?
"Day 2 Grocery Getter"
68 SSRS 427 Dana Camaro
Old 10-03-2022, 01:03 PM
How about this one??
https://www.ss396.com/chevelle/ACS-0069.html
Old 10-03-2022, 07:17 PM
That should be a lot better. A lot more springs
The Following User Says Thank You to luzl78 For This Useful Post:
Lee Stewart (10-03-2022)
Old 10-06-2022, 01:53 PM
ban617 ban617 is offline
I would have thought that a 427 would have had 2 springs on the carb … I guess it probably didn’t matter much because in Nhra & most drag racing have a rule 2 return springs on the carb …
Old 10-15-2022, 10:17 PM
68 DANA's Avatar
That will work, but that spring is for a 68 model year, 302 Z28, 396/427 GM#3923501.
Old 10-15-2022, 10:24 PM
68 DANA's Avatar
I ended up extending the two springs and interlaced them together. That arrangement worked.
