Old 03-21-2019, 02:44 PM
dlv4540 dlv4540 is offline
Default 1969-70 396 427 High Performance Parts
ZL1 aluminum tall deck block casting number 3946052 with a date on the backside of 06017 and is a 4.40 standard bore. The block was pressure tested and is ready to build $8,000.
1970 396-375HP 4 bolt block #3969854 dated H-20-9 with CKO code and W in vin for willow run. Block is .030 with two sleeves cleaned, magged and pressure tested and comes with the 11 to 1 pistons and dimple rods, 6223 steel crankshaft .010 under, 3964291 heads dated F-6-9 & F-18-9 cleaned and magged with hardware to rebuild and new oil pan $3750. A couple of the rods are non dimple so will toss in a complete set of 8 dimple rods with this package. Will separate out the heads.
1969 3919840 square port heads dated J-30-8 & J-31-8 with a new set of hardware to rebuild $1350.
Can ship if you cannot pick up and can be reached at 330-770-2517 for any questions or pictures needed.
Dennis Vugrinovich
Old 04-01-2019, 07:51 PM
bump
Dennis Vugrinovich
Old 04-01-2019, 07:53 PM
daverd daverd is offline
Wow I wish I had the room for this
Would make a killer nova for the street.
2013 Silverado
2017 impala
1970 Raylle 350 post coupe
1971 442 W 30 holiday coupe
Old 06-01-2019, 01:10 PM
bump
Dennis Vugrinovich
Old 06-13-2019, 09:59 PM
Updated
Dennis Vugrinovich
