Old 11-17-2020, 02:16 PM
TomN TomN is offline
Maybe one of you have had experience with something like this. What would happen if a car with resistor wiring also had a coil with an internal resistor?
Still trying to figure out why car has no power.
I'm also looking at the cam as a possible problem too. I've set the valve lash a few times and the 'clicking' always comes back. I had blamed it on the crimp style adjusting nuts but last time I put on poly-locks.
Been busy on other projects so haven't been working on this as much lately
Old 11-21-2020, 10:46 PM
If the coil doesn't need a resistor wire (because it is internally resisted) then the combination of voltage drops may bring it down to 3-4 volts-
Pull the positive wire off the coil, attach a multimeter visible inside the car, then click the switch into the RUN position and check the voltage - if there is a resistor wire I believe the voltage should be 7-8 volts.
Poly locks will come loose if the top of the stud is not flat and square, many times the studs must be machined in order to achieve such a state.
Are you cold lashing or hot lashing the valves?
Many of us prefer to cold lash them... if you are not doing it this way here are the procedures as laid out by JohnZ and Duke Williams. PLEASE refer to your cam card or check your documentation for the appropriate clearances.
Procedure is as follows:
Bring #1 to TDC on compression stroke - adjust 8E 2I
- rotate the crank 90deg adjust 4E 1I
- rotate the crank 90deg adjust 3E 8I
- rotate the crank 90deg adjust 6E 4I
- rotate the crank 90deg adjust 5E 3I
- rotate the crank 90deg adjust 7E 6I
- rotate the crank 90deg adjust 2E 5I
- rotate the crank 90deg adjust 1E 7I
Old 11-22-2020, 05:55 PM
Thanks firstgenaddict
I've tried a different know good coil and had about the same results as with the coil that was on the car.
I did cold lash the valves. But...since I bought the car with the engine in it, I don't have any cam specs. So I set the lash at .024 I and .026 E.
Let me say that I had a 427 years ago with a cam going bad. If I drove the car 5 or 6 miles the valve lifters were not clicking - they were clacking.
I am just having a little clicking with this engine/cam - so if it is going bad, it is just starting. Thought I might drain the oil and see if there is anything.
Since I have tried a different distributor and now a coil - I may try a different carburetor to see if I can find where the power is.
Thanks for all the help
Old 11-27-2020, 02:21 PM
To adjust the lifters I had used the method from an old camshaft installation guide -
Turn engine until exhaust valve starts to open (about 1/5 of the way) then set intake valve
Turn the engine until the intake valve has opened fully and then is about 1/3 of the way closed - set the exhaust valve
The stock balancer is not marked like an aftermarket performance one is
May have found where a lot of the power this engine should have has been hiding - will take the car out again soon - but may go back through the valves again first
Old 11-27-2020, 04:02 PM
Have you confirmed the Timing Chain is correctly mounted as a tooth out would run but be low on power?
Best of luck, lookin' good otherwise!
Old 11-28-2020, 09:06 PM
Well, I did adjust the valves and then take the car out to see if it was any better ... and it was only a little better
But when I got back home (5 miles top) there was those clicking lifters again
Cam will just have to come out
Old 12-01-2020, 04:58 PM
realzed realzed is offline
I thought I heard there was both a grooved or plain journal cam that could be mistakenly installed that could lead to problems in one of these engines (375 hp)..
Maybe I'm way off base here- but could it possibly be that yours has the incorrect type for the block you have and that could be your problem?
Old 12-02-2020, 12:02 AM
Well the block in the car is a 1969 according to the numbers on it .... so it shouldn't need a grooved rear cam journal
I think the cam and lifters are just gone - maybe never broke-in right
Old 12-11-2020, 01:56 PM
My 72 y/o back is bothering me so I might be a little slower now - for a while - getting to some of this.
But I am hoping to start getting the fluids out of the engine so I can start taking things apart before to long.
Old 12-14-2020, 07:29 PM
Well the cam is gone. i think that is what has been wrong with this car since it has been here. It wasn't the carb or distributor, etc. like I hoped.
Hopefully the cam will come out without having to pull the engine - has anyone here pulled the cam from a 69 Chevelle with a big block engine and know for sure? I tried to do some measuring and it looks close.
