#11
Re: e-bay, UNREAL, 67 RS/SS,Title.
Ok, semi-on topic post here...you guys tell me more about those 6-banger sprints! How would one do in a Firebird? Did they have 4-barrels and dual exhaust?
#12
Rob, They had high compression heads (I'm guessing 11:1, but don't know for sure--had to run High test gas), Rochester 4 bbl. Mine had single exhaust. However, I remember I had a hard time finding a replacement exhaust pipe. I can't remember the details, but I found one that was listed for my car, but when the guy brought it out, it had a wye on it that was crimped and welded shut. I'll bet at least some of them were dual exhaust.
They also had heavy duty "GTO" suspension , and came standard with a 3 speed and Hurst shifter. mine had an open rear, but I don't know the ratio. Stock Lemans badging with a 3 stripe (two 1/4" with a 2" in the middle) located about halfway up the sides between the wheelwells. The word "SPRINT" replaced the center of the stripe on part of the fender. I think it was a 250 ci with 230 hp. Drum brakes all around. When I first started looking for a car, there was a 69 Firebird Sprint 4 speed convt. that had some Lingenfelter work done to it. It was around Blacksburg Va, but I never went to look at it. |
#13
Theres a for sale sign posted here at the Auto hobby Shop selling a 67 Lemans Convt/6 cylinder for $2500. From the pics it looks like a nice car but one would still have to get up close and look even if its as cheap as it is.
IF YOU DON'T STAND BEHIND OUR TROOPS, PLEASE, FEEL FREE TO STAND IN FRONT OF THEM !!! |
#14
I have a 67 Bird with a Sprint Engine. They'll suprise alot of people. There pretty quick 0-60. They have a 6500 rpm redline from the factory. They have some decent torque. Mine is a 4 speed (most where 3speeds manual or 2 speed auto), the 4 speed had 3.11 first gear. Fun drive because you have the extra rpm with some torque to play with (front end is a little lighter too).
All Sprints where single exhaust, but they came with a split manifold so it's easy to make true dual. Compression was around 10.5 from the factory. There are some sleeper out there, people put superchargers on them, or triple Webers. Something different to play with if nothing else.
Rick ------------ 1967 Fitch Firebird |
#15
Wasn't the sprint engine one of the first to use a timing belt to drive the cam?
#16
Were the block/heads iron or aluminum? Any idea what the weight of a Firebird with the Sprint-6 and a 4 speed would weigh?
#17
Jaguar I think around the same time had a belt driven OHC engine, I'm not sure though.
The block and heads are cast iron, the cam cover is alum. One of my Firebird books quotes a 400ci Bird weighing 3250 lbs. It also said the OHC engine saved about 180 lbs in weight up front versus the 400ci. Doesn't mention what tranny.
#18
There is a nice Gold OHC6 for sale right now in the Old Car Trader...convertible
<span style="font-weight: bold"> (__{B}_____]]]]~~~~</span> Don't mess with old farts - age and treachery will always overcome youth and skill! Bullshit and brilliance only come with age and experience. |
