weird date code
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue |
Whats so weird about it? Its 11C. Unless you are talking about the paint on the tag making the C look like a 6?
If you look closely you can see the raised stamping is clearly a C
1969 Camaro RS/SS Azure Turquoise 1969 Camaro Z/28 Azure Turquoise 1984 Camaro z/28 L69 HO 5 speed 1984 Camaro z/28 zz4 conversion 1987 Monte Carlo SS original owner |
sure looks like 116
It does,but it doesn't resemble the other 6's and has a smaller lower case circle as well as a closed upper case,compared to the others.
It's probably the angle or a dimple making it look like a 6,when it's actually a C. Last edited by Mr70; 03-27-2017 at 12:01 PM. Reason: pic |
I see 11C also.
Mike |
Wire wheelcovers! Dare to be different!
