Vapor Blasting
Has anyone used vapor blasting to clean aluminum parts like intake manifolds and valve covers.
Chuck Burg just used it (happily) on his Dad's original '67 L78 Chevelle intake.....
The Following User Says Thank You to tom406 For This Useful Post: | ||
mhm1966 (01-29-2021) |
I had a friend vapor blast my aluminum valve covers. I had already bead blasted them with glass bead. The vapor blast darkened them just a bit and created a better fingerprint-resistant finish.
SOLD 1969 427 COPO Camaro Lemans Blue/Black, M22 4 speed, 15,800 original miles |
The Following User Says Thank You to R68GTO For This Useful Post: | ||
We use it extensively in our shop, lots of examples on my build thread (eg post #343) https://www.camaros.net/threads/1969...337897/page-18
It works well on aluminum but not normally to clean it as vapor blasting is a finishing process. Mostly we first solvent tank the part to remove grease, then dry media blast before vapor blasting for the best results. Last edited by Edgemontvillage; 02-03-2021 at 07:46 PM. |
68,69&2015 Z/28's 69 L78 Nova Purchased new 32k miles 69 Restored Nova L34 Father/Son Few Corvettes Our 68 Z/28 Build thread- http://www.camaros.net/forums/showthread.php?t=182584 |
Hi Chick, if you have a look at Post #343 on my build thread there's an example of an intake I vapour blasted for a buddy with a 69 Z. It appears shinier in the photo than in person due to the lighting. I also did a set of valve covers for a friend who has a '70 Z and compared them with a set I sent out for reskinning - can't tell them apart. We also have a tumbler in the shop and a variety of ceramic media that works well on parts like intakes that don't have fine crevasses that the tumbler media can't reach.
The Following User Says Thank You to Edgemontvillage For This Useful Post: | ||
68camaroz28 (02-04-2021) |
I believe David Beem does vapor blasting.
Rick Nelson Musclecar Restoration and Design, Inc www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specializing in (only real) LS6 Chevelle restorations |
The Following User Says Thank You to SS427 For This Useful Post: | ||
protree68 (02-18-2021) |
This thread will provide you some pictures of some tumbled intakes as well as intakes that were vapor blasted. Take your pic.
https://www.yenko.net/forum/showthread.php?t=163882
I like solid lifter cars, big cams and cars w/ 3 pedals in them. |
The Following User Says Thank You to NorCam For This Useful Post: | ||
As previously mentioned, I used it on my dad's intake manifold and thermostat housing. Inexpensive and amazing. The vapor honing actually seals the aluminum on a molecular level making it more impervious to stains. Highly recommended!
I can reskin the aluminum intakes they look factory
