Old 07-17-2018, 01:34 AM
Default Gas Tank Sending Unit Trouble Shooting
Thought I’d share some findings I discovered tonight. My fuel gauge has never worked as long as I have owned my Chevelle. My plan was to remove it and send it to a shop here in Ohio for a rebuild. I decided to check the resistance with my multimeter to see what was what.
1st up I noticed that I had an open circuit (1st photo) when I touched the multimeter positive probe to the sender post with the float at its empty-tank position. When I flexed the probe to one side or the other I was able to read a low resistance (.9 ohms) intermittently (2nd photo). Then with the probe flexed to the side i was able to get a reading of about 92 ohms with the float at the full-tank position (3rd photo)....
Attachments - The Supercar Registry hmmm.gif FBEB0AD5-4E4F-492A-92EF-7178205EA84E.jpeg F7E8974E-40BA-44F6-8CB3-CF76DA378A40.jpeg EBAF53C7-F0A8-4F25-9BEA-3EFB76B68A56.jpeg
Old 07-17-2018, 01:40 AM
ssl78 ssl78 is offline
Where the stud goes thru the sending unit it usually looses connection. I have taken the push ring off wire brushed everythig and put it back together and then it works fine.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
The Following User Says Thank You to ssl78 For This Useful Post:
mockingbird812 (07-17-2018)
Old 07-17-2018, 01:51 AM
On the under side of the post I noticed the retaining nut was corroded. This nut (1st photo - green arrow) is responsible for making the connection between the post and the conduit (2nd photo - blue arrow) that connects to the float mechanism that measures resistance based on the float position. i disassembled it and found that there did not appear to be a good connection with the conduit that connects to the float mechanism. I cleaned up all metal contacts at this junction and made a new rubber gasket (2nd photo - green arrow) to electrically isolate the post from the sender frame. The old gasket was deformed and too thin (2nd photo - red arrow). Once this was done the connections worked just by touching the multimeter probes to the sender post and the ground wire. I am hoping this has fixed my problem. I’ll hook the sending unit up to the gauge lead tommorow before reassembley to ensure the sender is sending a good signal to the gauge.
Old 07-17-2018, 01:53 AM
Ha, you beat me to it!!
Old 07-17-2018, 12:31 PM
bbbentley's Avatar
Never have I done what I am about to suggest, but do you think a little solder on that whole pin, nut, wire area would insure this would not happen again and prevent corrosion at that point? I just believe that that if I have to fix something, I’m going to fix it for good ‘ cause I don’t want to have to do it again. As a disclaimer- I am a purest and want things correct. I also don’t want to re-engineer what GM did, but something unseen and if I can make it better, (even if it is just better in my mind) I’ll try. I probably put too much thought into stuff?
BTW Sam, great diagnostic skills!
FULL OWNER HISTORY
The Following User Says Thank You to bbbentley For This Useful Post:
Old 07-17-2018, 01:04 PM
Bentley - the same thot crossed my mind. IMO, this is a simple, but poor design. It creates a high likelihood that corrosion will play havoc on the system. I think solder might do the trick. Thanks!
tunes (07-17-2018)
Old 07-17-2018, 04:00 PM
You have to remember, GM did not intend these things to last 50 years, so the design may leave a little to be desired
I know John suggested the same thing when I had problems with the sending unit on my Post Sedan. I could not get that push nut thing off to save my soul, it just dug in more when I tried to remove it. With all the fragile components on that sending unit, I figured I was going to end up doing more harm than good, so I just sent it off to John Wolf & Co. in Willoughby OH and they fixed it up good as new. I am now having the same issue with my convertible, so I might try this again when I get around to fixing it.
Bill Pritchard
Old 07-17-2018, 07:30 PM
Bill one of the times i did it i cut the retaining ring off and bought a new one I think Ace hardware has them
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 07-17-2018, 11:04 PM
Test complete. Float in down-most position. Float in up-most position. Right as rain!
Old 07-17-2018, 11:38 PM
Damien Damien is online now
Good info Sam!
1969 SS 396/350 Chevelle
