Old 09-14-2018, 06:49 PM
Yes, the cowl hood does look good. I have a 3 1/2 inch cowl hood on my car now, but I would want to use the shorter 1 5/8 hood with the tunnel ram so that more of the carburetors would show, or at least the velocity stacks would show.
markinnaples (09-14-2018)
  #12
Old 09-14-2018, 09:36 PM
markinnaples markinnaples is online now
Yeah, that higher cowl hood probably wouldn't let the velocity stacks be seen as much. Even my shorter cowl hood doesn't show my V-stacks very much when I have them on it.
1968 Camaro Ex-ISCA Show Car
John 10:30
big gear head (09-15-2018)
  #13
Old 09-15-2018, 02:10 AM
The only thing I've been able to fond in a fiberglass short cowl hood is a 2 inch Harwood. All of the others are 3 1/2 or more.
Old 09-15-2018, 07:03 AM
COPO COPO is offline
Why not a fiberglass flat hood to show off the Tunnel Ram?
The Following 2 Users Say Thank You to COPO For This Useful Post:
big gear head (09-15-2018), markinnaples (09-16-2018)
  #15
Old 09-15-2018, 01:31 PM
That's not a bad idea. I'll see if I can find a bolt on flat hood.
Old 09-26-2018, 04:33 PM
Bernhard Bernhard is offline
X2 flat hood steel or fiberglass.
The flat hood provides a cleaner line and showcases the carbs and air cleaners.
69 442 post bench 3 pedal
The Following User Says Thank You to Bernhard For This Useful Post:
big gear head (09-26-2018)
  #17
Old 09-26-2018, 07:44 PM
Unlimited makes a flat bolt on fiberglass hood. I have a Unlimited hood on my car now, but shipping it from California is expensive. I was hoping that I could find a dealer somewhere closer, but I haven't found anything yet. Most of the flat hoods are lift off, but I want to bolt it to the hinges. There is no hurry on this, so I'll keep on looking. Right now I'm still looking for a 1850-1 with a date close to 0817 to match the one that I already have.
Old 09-26-2018, 08:12 PM
Check out Tamraz's on ebay. They have a ton of options for hoods for you car. And Glasstek build an ton of fiberglass hoods for them.
The Following User Says Thank You to chevyandpontiac For This Useful Post:
big gear head (09-27-2018)
  #19
Old 09-26-2018, 09:13 PM
YENKO DEUCE REGISTRY's Avatar
We obviously like the flat hood look as well, really allows the TR and Holley's to show...
Marlin
The Following 3 Users Say Thank You to YENKO DEUCE REGISTRY For This Useful Post:
big gear head (09-27-2018), markinnaples (09-27-2018), PeteLeathersac (06-16-2019)
  #20
Old 09-27-2018, 01:02 AM
Yes Marlin, I've looked at your car several times. I think you have the same Offy TR that I have, so mine is going to look a lot like that. Do you have any problems opening and closing the hood with the velocity stacks on? I was wondering how large the hole would have to be to clear the carbs and stacks.
