Old 07-15-2019, 09:47 PM
Enoch Enoch is offline
Exceptionally nice s stamped plates dial distributor hold down clamp and SB head marking bolt. $45. Ppff (X)
Old 07-15-2019, 10:05 PM
Very nice original restored emergency brake cable to brake pedal attaching clip. Replated and has its original C manufactures stamping on it. $25 ppff
Old 07-15-2019, 10:11 PM
Exceptionally nice three-quarter inch heater hose to water pump fitting, long style with notches on corners of each hex. As nice as you'll see. $60. This is correct for short water pump style Motors. Both small and big block.
Old 07-15-2019, 10:40 PM
69 through 74 small block and big block smog pump mounting hardware. All are matched RBW head marking original restored bolts. Long pivot bolt, 2 7/16-14 bracket to block mounting bolts 1 3/8- 16 adjuster Bolt 3 1/4-20 short Pully to pump bolts and 2 diverter valve mounting bolts. Everything is in excellent restored condition. $80 PP FF
Old 07-15-2019, 10:57 PM
Extremely nice original pair of throttle rod + accelerator lever nylon bushings and rubber grommets. This is one of the assembly line style bushings with the three dot mold release marks and manufacturer embossings. Very hard to find this dial. $50 for the pair Ppff (X)
************SOLD************
Old 07-15-2019, 11:11 PM
Excellent original Allen head door Strikers restored with 2 W - 2 stamped thick 1/8" washers + 2 W - 1 stamped 1/16" washers so these can be shimmed perfectly for your car. As nice as you'll see Originals. $50. Ppff 2 sets available
*** one set sold one set still available***
Old 07-15-2019, 11:28 PM
Restored original brake and fuel line clamps. 9 5/16 and 2 3/8. $15 each PP FF $3.50 to ship one clamp. Two or more clamps free shipping
Old 07-16-2019, 12:04 AM
Cool
Restored brake and fuel line clamps. 9 5/16 clamps and 10 3/8 clamps. $10 each and $3.50 to ship. Free shipping on two or more clamps. Excellent restored pieces.
Old 07-17-2019, 06:52 PM
Wheel well to fender U nuts for chevelles $35 ppff
Old 07-17-2019, 06:57 PM
Small block high performance 87° water pump bypass fitting. Excellent original restored piece. $50 (X)
