Old 07-29-2019, 07:01 PM
ALLZS ALLZS is offline
Default Leaf spring color
what is a good color match & brand for flat cast iron paint to coat a set of leaf springs
Old 07-29-2019, 08:30 PM
Look at the pics in the first post of this thread:
https://www.yenko.net/forum/showthre...d+pics+project
They may be a little light. They still look the same today, seven years later. I believe I covered the procedure I used in another thread. I will hunt it up if you want.
Old 07-29-2019, 10:11 PM
Canuck's Avatar
Canuck Canuck is offline
After my springs were media blasted,I coated gem with a graphite spray, then assembled.
I will see if I took photos.
www.vancouverclassiccars.com
The Following User Says Thank You to Canuck For This Useful Post:
enio45 (07-31-2019)
Old 07-30-2019, 02:40 AM
what brand of graphite spray did you use some pictures would be great thanks
Old 07-30-2019, 03:59 AM
I set out some of the procedure I used starting in post #55, on that thread, I believe.
Also, found the other thread on the technique I used for the springs.
https://www.yenko.net/forum/showthre...f+springs+lynn
Hope that helps.
