Old 04-19-2019, 08:45 PM
Enoch Enoch is offline
NOS rear JL8 + j56 caliper bracket to rear end housing mounting bolts. These literally have been sitting on the shelf for 50 some years. 4 sets available. $55 a set ppff
Old 04-20-2019, 02:20 PM
Default ABout time for a new megathread of parts for sale
Rich: Don Martens here. I'll take 2 sets of 69-74 396 427 454 long water pump bolts- one set M head marking, the other set RSC headmarking. Add Big Block 396 427 454 D headmarking valve cover bolts. Add unrestored Eaton petcock. I'll PM you with info. Thanks, Don.
Old 04-24-2019, 12:16 PM
70-72 Chevelle rear bumper Hardware $45 PPFF
Old 04-24-2019, 12:18 PM
67-69 Camaro e-brake rod original replated. $45 PPFF
Old 04-24-2019, 05:21 PM
Camaro Nova Chevelle c48 heater delete block off plate mounting bolts. Original unrestored head marking. Included are nine original bolts used for this application. $60.
Old 04-24-2019, 07:11 PM
************ sold ************
Old 04-24-2019, 07:24 PM
Camaro Chevelle Nova Firebird grill and headlight bezel U nuts/J clip with P stamping. 8 very nice restored pieces. $50.
*********SOLD **********
Old 04-24-2019, 07:30 PM
Original early style 3 dot power brake booster check valve. Excellent working condition. $30.
Old 04-24-2019, 09:38 PM
Original 67 through 69 Camaro Nova front sway bar end play rubber bushings. These are the rubber bushings that bolt right next to the sway bar to frame mount to stop side-to-side movement. Only the original ones have the three or four ribs on them. These are very nice original pieces. $50.
Old 04-24-2019, 09:40 PM
Original 67 through 69 Camaro Nova Firebird front sway bar bushings. Excellent original pieces you can still see the factory saw cutting marks on the sides. $40.
