Old 10-23-2020, 08:48 PM
Default Welding Muncie handle to Hurst shifter????
Hi everyone,
Just bought a '67 Camaro real 4K L78 car. Already hate the Muncie shifter as it is now bound up in reverse. Fortunately, I was able to back into my garage and I'll have to get under this weekend and get it unlocked.
Plan is to order a Hurst Competition Plus shifter and linkage kit (pretty spendy over $700) and then cut the shifter handle off and weld the Muncie stick to it as I am a purist and want to maintain the stock look.
Seems straightforward enough. Any concerns guys or tips?
Thanks,
Paul
Paul
'62 Bel Air 409/409
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Attachments - The Supercar Registry Shifter Hurst 4.jpg Shifter Hurst 3.jpg Shifter Hurst 10.jpg Shifter Cleaned.jpg
Old 10-23-2020, 10:29 PM
SS427's Avatar
SS427 SS427 is offline
I am pretty sure you can purchase a reproduction Muncie handle that is already made to fit the Hurst shifter mechanism. You won't ruin your original handle and is less expensive then rechroming the one you cut and weld. They make them for the Chevelle so likely made for the Camaro as well.
Rick Nelson
Old 10-23-2020, 11:17 PM
rszmjt rszmjt is offline
A 67 Camaro factory handle can be cut off & drilled to match the Hurst shifter stub, unless you want to save it, like Rick said they may make a handle now. Hurst pricing has got stupid in last few yrs.
Mike
Old 10-24-2020, 12:02 AM
tunes's Avatar
tunes tunes is offline
Mike
This is what I did (cut and drilled) with my shifter and it was pretty easy.
Robert
_______________
2023 Stingray Coupe Z51
Old 10-24-2020, 12:24 AM
169indy's Avatar
169indy 169indy is offline
Paul, I am in the exact same situation. Finding it Difficult on taking the Death=Wheel to my Org "MUNCIE" chrom plated handle.
I bought the Plated version of the 67/68 shifter then ordered a 3/8UNC 'chrome' ball.
Also picked up: Hardened Bushing and properly sized New Clips
Source 5SPEEDS.COM
I am not positive they are Making a "F" Body Handle yet, I might have not looked hard enough tho.
Anybody got the Source and Part number for this Muncie Logo Hurst handle? (I have see Chevelle Handles of this description from the ("Parts Place")
Jim
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 10-24-2020, 12:34 AM
Maybe Joe at the parts place repos it or should? I thought Ground Up reproduced it before ? How close is a Chevelle handle shape?
Old 10-26-2020, 03:47 PM
Thanks for the tips guys. I have the Hurst on order. Will let you know how it goes.
Paul
'62 Bel Air 409/409
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 10-26-2020, 04:23 PM
m22mike's Avatar
m22mike m22mike is offline
Glad to see you are installing a Hurst , I dought you will ever go back .
Old 10-26-2020, 04:35 PM
Well, installing a Hurst, but making it appear to be a Muncie! But yeah, need to be able to shift this thing!
Paul
'62 Bel Air 409/409
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 10-26-2020, 10:31 PM
I did the same thing with mine, but it's harden steel. I used a high speed drill bit for the holes. It will sit a little higher than stock, but you'll be the only one that knows it.
