#21
Re: Question about BB 4speed crossmember
Hmmmm... I thought the shifter rods made up that difference, but not completely sure
#22
Your setup is fine, there are deuces with 100k+ miles on them with the mis-matched components - without problems! The universal joints make up for any alignment issues. I'm not sure I'd be throwing a set of slicks & caltracs on there, but for 'normal' usage it will be ok. [/ QUOTE ] Marlin, I'm a little confused here. The Deuces are LT-1 drive trains and as such would use a SB X-member - right? Also, if the SB works, why did GM use the special BB 4-speed X-member we are discussing here? As I mentioned earlier, every BB 4-speed Camaro I ever saw ( correct ) used this special X-member. You're obviously knowledgeable about this stuff and I hate to disagree with you, but I just don't see the SB X-member being correct. I'd welcome your comments otherwise. Always good to learn from others. Steve
Good info here Gents on a much over-looked topic. Allow me to add a little more: The OEM shifter mounting holes are different relative to the tranny mounting holes on big block xmembers. They are offset to the left about 1/4" compared to SB. This allows the BB shifter linkage to align correctly. Yes, a mismatch will work, but thats not the way they were from the factory. This applys only to 67-8 Camaros. [/ QUOTE ] 69 only has a similar issue. The shifter rods are about 1/3" longer to accomodate the mounting of the shifter with that special ( again, BB only ) horseshoe mounting plate. 69 BB's have lots of these accociated issues. The lower reverse lockout rod is also different for BB 4-speeds. The flat nut for the Hurst shifter adjustment is a racetrack shape vs. the rectangular shape of the SB's. Once you start you just can't stop. Steve
I hear ya! We actually don't know why GM installed the BB transmission crossmember with the LT1 application. We have confirmed that the engine mounts are indeed the SB version, and the crossmember is not the Pontiac version. I wish I could tell you why, but.... that's GM
We have speculated that the BB Xmember was retained under the COPO 9737 package because that package had been applicable to only BB cars for the prior two years, but we agree that it's a stretch and pure speculation. The deuces actually have the BB shifter rods, but the SB shifter attaching bracket (no 1/2" offset), along with the '69 Camaro Z28 shifter mechanism with a Pontiac GTO bench seat arm. Confused yet?
#25
No,
But you pretty much ruined my day
Hmmmm... I thought the shifter rods made up that difference, but not completely sure [/ QUOTE ] Many people think there is no differance. The BB linkage and the stablizer shaft are offset to align with the BB xmember. The assembly manuals show this and I've noted it on a number of unmolested BB cars thru the years.
Craig S. "I saw Elvis At 1000 Feet" John Force. |
#27
[ QUOTE ] Hmmmm... I thought the shifter rods made up that difference, but not completely sure [/ QUOTE ] Many people think there is no differance. The BB linkage and the stablizer shaft are offset to align with the BB xmember. The assembly manuals show this and I've noted it on a number of unmolested BB cars thru the years. [/ QUOTE ] Craig, What's a stablizer shaft? Steve
Steve,
The stabilizer shaft attaches to the shifter body, extends foreward, and attaches to the tranny via a bracket. The 69 factory Hurst didn't have one.
#29
Oh, I got you, the Muncie shifter thing.
Steve
Oh, I got you, the Muncie shifter thing. Steve [/ QUOTE ] Yep. Most, if not all the "Bolt to the x member shifters" got one. Ditto for Chevelle and Nova although they are different from Camaro. The repops on the market are generic and may or may not fit a particular application.
