409, 348 parts
I've had these parts kicking around my garage for a long time and thought maybe someone could put them to use.
I have no idea what they're worth, so any suggestions would be appreciated. All but one AC Delco piece came from International Parts Corporation. All appear new, or rebuilt and most of the parts have the corresponding GM part number on the box. Fuel pump GM part #. 5594460 Int'l part #4460 Fuel pump 1963 409 Int'l part number 6842 There is 2 of these. Fuel pump 1961-62 348 with high lift cam GM# 5594799 Int'l part # 4799 Fuel pump 1959-62 GM# 5594657 Int'l part # 4657 Fuel pump rebuilt AC Delco GM # 24657 Fuel vacuum pump 1958 348 with 3-2 barrel carbs GM part # 5594490 Also have a waterpump that I'm guessing is aftermarket also as I see no GM part# 2261 is stamped on front, only numbers I see on it. It is new, or rebuilt. Don't have a box for it, all the others are boxed. If anyone has an idea of what this stuff is worth, I'd appreciate any help Vern |
AC Delco Fuel Pump
Hello Vern......I would be interested in the 5594657 AC Delco Pump.
Thank you, Tom |
Pm sent.
