Old 12-18-2021, 09:52 AM
TimG TimG is online now
Amazing work, thank you for posting. I will be following the build.
Too Many Projects (12-18-2021)
  #12
Old 12-18-2021, 06:34 PM
Great work. You are a true craftsman. Thanks for sharing.
Jason
  #13
Old 12-23-2021, 12:00 AM
Monday, I was burning off the remnants of an old, brazed on, patch when I realized I had my lower door brace welded to a panel I had to replace...
I cut another tube and moved it back and up on the vent panel.
This is the replacement part.
In the process of doing that, I was wire wheeling the area and found rust damage in the toe board and pillar. That was to be Tuesdays work.
I cut the toe pan out and made a tag board template and then rough cut a piece of sheet steel.
I then bent the weld flange and used the stretcher jaws to give the piece some curvature to match the floor.
I didn't take any pics of the pillar patch, but here they are drill screwed in place for floor pan test fit.
The Following 4 Users Say Thank You to Too Many Projects For This Useful Post:
big gear head (12-28-2021), dustinm (12-27-2021), olredalert (12-27-2021), SS427 (12-28-2021)
  #14
Old 12-23-2021, 12:34 AM
Today, I made the patch for the right side inner quarter structure. I wasn't completely happy with the way the left side fit and looked, so I made this one to fit inside the existing panel. Looks WAY better in there.
On this side, I cut out the rotten wheel house so I could extend the patch far enough to cut and form to the new house.
Here's a "stop" the owner screwed on 51 years ago to fill a large rust hole with bondo...
Seems I forgot to take a pic of the bondo mountain under the stop.
New panel all formed and cut to fit.
Much better looking and easier to weld too.
I liked how this fit and looked so well, I modified the left side to be the same.
In getting ready to test fit the floor pan, I had to remove the weld flange remnant from the toe board. I don't like spot weld drills for this, as they partially cut into the panel I want to save. Using a grinding wheel is my preferred method of spot weld removal and then clean up the flange with a 80 grit disc.
Then I started mocking up the new wide wheel tubs. These are for a sedan, so I cut off the lower part that won't be used on the wagon.
I layed it in place, to get an idea of where I was going to go with this and it seems that it will be easier than I thought to graft this onto the wall. Cutting the cabin and cargo floors will be a challenge.
As well as getting the radius cut in the existing panels to fit the new house into the wall and blending it so it looks like to belongs there.
Test fitting the cabin floor is about the next move, so I have to remove the rest of the old cabin floor at the cargo floor. There is a brace under this to reinforce the cabin floor, so I just drilled thru all 3 panels to remove the floor remnant and brace. Only got halfway thru when the time bell rang. I'll get this out and the floor layed in place next Monday. I think the car will take on a pretty cool appearance with a complete, new floor sitting place...
Thanks for tuning in for the fun and butchery.
The Following 8 Users Say Thank You to Too Many Projects For This Useful Post:
69M22Z (12-27-2021), big gear head (12-28-2021), dustinm (12-27-2021), ORIGLS6 (12-23-2021), PeteLeathersac (12-23-2021), ruralrte66 (12-27-2021), scuncio (12-23-2021), SS427 (12-28-2021)
  #15
Old 12-27-2021, 01:37 PM
dustinm dustinm is offline
Love it!!! I have a 55 2 door sedan that needs some of this same treatment, so I will be learning off this.
The Following User Says Thank You to dustinm For This Useful Post:
Too Many Projects (12-27-2021)
  #16
Old 12-27-2021, 09:52 PM
Got the last of the original floor remnants ground off this morning and lifted the floor into place with the lift for a trial fit. I gotta say, this floor fits about as good as anything you could get. I left as much of the original weld seams on the car as a reference and it matches very well.
I've put a number of 1 piece pans in vehicles now and it is still cool. I work 2-3 days getting ready for this and end up with a big hole and, wha-la, 1 piece and it looks like a vehicle again.
Since that fit so well, I went after removing the left outer rocker cover the owner installed in 1970. I couldn't tell exactly where his seam was, so I just used the stone grinder to remove the edge of the metal, to preserve the original underneath.
I only saw the one spot weld and wondered why. I found out quickly when I started grinding off the paint. The whole seam is leaded... That's tomorrow's removal process.
69M22Z (12-27-2021), big gear head (12-28-2021), PeteLeathersac (12-28-2021)
  #17
Old 12-28-2021, 01:53 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Great job of rust repair there Mitch. This looks like a fun project. I know I will enjoy watching the progress of this one.
The Following User Says Thank You to Jonesy For This Useful Post:
Too Many Projects (12-28-2021)
  #18
Old 12-28-2021, 02:06 AM
My uncle has a '55 handy man wagon. I'm about to start doing the same thing to it. I've already done the frame modifications so that wider tires will fit the rear.
Old 12-28-2021, 02:18 AM
I was on the tri-five.com website and read thru a gasser build. That guy flipped the stock spring mounts from side to side and moved the springs inboard of the rails. That is what I'm going to do to his. No frame mods at all.
Old 12-28-2021, 03:32 AM
I think this is what I used. https://www.performanceonline.com/19...caAl09EALw_wcB
