1970 Chevelle NOS Parts L@@K Many Different some fit other models Parts
-14015391 Lower bracket 14015392 Upper bracket and 3967424 Spacer, three piece Power Steering Pump hold down set 2nd design $100
-3880140 12 bolt open rear axle pinion gear $35 each -3954480 Axle Crush Sleeve spacer $15 each -7806748 Manual Steering Cover Cap kit $75 -7826470 Power steering pitman shaft seal kit $40 *SOLD* -3973060 Tilt or Turn Signal Knob $60 each -3865886 Distributor to pump shaft for big blocks $60 each -337559 Thick washer $10 each -1362249 Bumper Bracket washers with serated teeth $10 each -1497525 EB Brake Cable Equalizer $30 -3654642 Steering Coupler nut $10 *SOLD* -15553615 Muncie rod retainers $10 each -3961580 Passenger side front stereo speaker bracket $70 -8796920 Convertible RR Weatherstrip $100 -7313151 Passenger side front stereo speaker with 3961580 bracket $150 Shipping extra depending on what you buy. Paypal "Friends"
"NOSTALGIA It takes us to a place were we ache to go again" Last edited by XXXGoldL34M20; 03-06-2021 at 08:22 PM. |
pm sent
NOS Power Steering Cap now *SOLD* Thank You The Horn Works & sYc
"NOSTALGIA It takes us to a place were we ache to go again" |
30 Day bump now 25% off these remaining items.
-14015391 Lower bracket 14015392 Upper bracket and 3967424 Spacer, three piece Power Steering Pump hold down set 2nd design $100 -3880140 12 bolt open rear axle pinion gear $35 each -3954480 Axle Crush Sleeve spacer $15 each -7806748 Manual Steering Cover Cap kit $75 -3973060 Tilt or Turn Signal Knob $60 each -3865886 Distributor to pump shaft for big blocks $60 each -337559 Thick washer $10 each -1362249 Bumper Bracket washers with serated teeth $10 each -1497525 EB Brake Cable Equalizer $30 -15553615 Muncie rod retainers $10 each -3961580 Passenger side front stereo speaker bracket $70 -8796920 Convertible RR Weatherstrip $100 -7313151 Passenger side front stereo speaker with 3961580 bracket $150
Dan. What color is the turn signal/ tilt knob?
