Old 06-06-2017, 07:57 PM
JRC99's Avatar
JRC99 JRC99 is offline
Also, for those in the Detroit area, the car will (possibly) be at the Barn show in Livonia this Sunday.
My cars, passed down by my grandfather:
'68 Camaro SS (454/TH400, possible L78/M22) LeMans Blue, black deluxe interior, black vinyl top. 3.73- mostly Day 2.
'89 Mustang GT- 3.55, subframe connectors, muffler delete, and a couple other minor mods. Exactly as he wanted it, so how it shall stay
Also:
1995 Ford F-150 XL
2004 Dodge Ram Hemi GTX- #192 of 433
Ain't no fun in viewing your car as an 'investment'. Get out there and beat on it!
Old 06-07-2017, 07:31 PM
JRC99's Avatar
Washed it again since we're taking it to a local cruise night.
Gotta admit, it sits *much* better now.
Also:
1995 Ford F-150 XL
Old 06-07-2017, 07:49 PM
cook_dw cook_dw is offline
Banned
Just a little tidbit on cleaning cars in general. Washing a car all the time seems like a great idea but if the car isnt driven the water that finds it way into areas you wouldnt realize. Driving the car after washing the car allows the water to be pulled out of those areas and to dry out. Washing and then putting in the garage will increase the speed of rust under the vinyl top and paint. Get some quick detailer in the spray bottle and a very good microfiber towel. I have not washed the green car in over a year and the blue 67 has been washed once since being finished back in 2015.
Also go to autogeek and do some reading on detailing. Especially about clay bar usage and paint polishes.
I appreciate your enthusiasm but unfortunately you could do more harm than good. Food for thought.
Old 06-07-2017, 09:16 PM
Great points from an expert Darrell, thanks for posting those up.
1968 Camaro Ex-ISCA Show Car
John 10:30
Old 06-07-2017, 11:06 PM
JRC99's Avatar
Noted! Thank you!
As an aside, OH. MY. GOD. This thing is brakesteering like you would not believe. So, no show for it this Sunday.
In addition, the shifter needs to be gone through (we ended up not sending it in- just never materialized)
"Now, one step foward and two steps back, nobody gets too far like that.
One step forward and two steps back- this kinda dance can never last!"
Also:
1995 Ford F-150 XL
Old 06-12-2017, 12:44 AM
JRC99's Avatar
On a brighter note, I just ordered the NCRS/CMD report. Hopefully whatever dealer ordered it
A: Is the one that sold it
B: Kept records.
Also:
1995 Ford F-150 XL
Old 06-24-2017, 06:07 PM
JRC99's Avatar
Report came in.
Official production date was March 19, 1968, ordered by Fairchild Chevrolet in Lakewood, Ohio.
The original location's now a Gordon Food Services. A newer location is now Pat O'Brien Chevrolet. I severely doubt they have paperwork from 1968. (Though it would've been unlikely either way). Damn, I'm never going to find out how it was optioned.
Also:
1995 Ford F-150 XL
Old 06-26-2017, 01:12 AM
This is a very cool car. Although I own a '69 RS/SS 396 4 speed car, the '68 SS 396 has always been my favorite. I also love the color of yours, and the Cragar SS wheels and air shocks are very cool. Your Papaw has 2 of my favorite cars. I had a '67 SS 396 Chevelle when I was in high school and I love that car.
I've had experience with the Comp Cams Magnum 305 cam. I've piut them in a few big blocks and they are a bit on the radical side.
I don't know if you got the carburetor and timing fixed by now, but most of the time when someone brings their car to me and claims to have a carburetor problem it turns out to be an ignition timing problem. If you have not already done it try advancing the timing until the idle speed picks up. This is usually where you will get the best throttle response. With that cam you are going to need about 12 to 18 degrees of initial advance. Also, plug gaps with the HEI are .045. You need to find true TDC and install a timing tape on the balancer. Then find the total timing at around 3500 RPMs. It needs to be about 36 degrees. If it advances too much then you may run into detonation problems.
Have you checked the numbers on the heads yet? If you have the closed chamber rectangle port heads then you might need a little more timing.
You mentioned a burnout a while back. Although they are fun, I have seen several people destroy their cars while doing this. Be careful.
Old 06-26-2017, 06:13 PM
JRC99's Avatar
I never did the burnout. I graduated before I could do it. As far as the timing, I still haven't checked it. The brakes need work before I get to that. I'm also certain that it's either timing or simply the trans not putting the power down, because the shifter is super sloppy. Haven't checked the numbers on the heads, either.
Also:
1995 Ford F-150 XL
Old 07-05-2017, 02:37 PM
Over Anxious Over Anxious is offline
What a beautiful 68 Camaro! Sounds like you are local to me as well. Maybe I'll see you at a show this summer
Joe in Detroit
Over Anxious
67 68 69 Camaros on Instagram
