Old 12-18-2018, 11:51 AM
madden madden is offline
Default Deuce lt1 head gasket thickness
hi
getting organized to assemble my deuce LT1 sbc
what is the correct head gasket thickness for original GM factory assembly application
using all std..original block/ heads etc
thanks
chris
1970 citrus Yenko Nova
Attachments - The Supercar Registry Intake Gasket 9-17-18b.jpg IMG_3471_intakegasket.jpg 00.jpg
Old 12-18-2018, 01:37 PM
BCreekDave BCreekDave is online now
I believe it is 0.015 steel shim. Use a copper coat or aluminum paint for sealing.
You may want to double check the deck height with the piston at TDC. Typically the piston is 0.025 down in the hole and with the 0.015 you end up with a quench of 0.040 which is about right. I say typically because this varied a bit form the factory.
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
madden (12-18-2018)
Old 12-18-2018, 03:36 PM
The factory correct intake manifold gaskets are not available, unless you are willing to trim them.
I last paid $450 for a complete set of NOS correct gaskets including the steel shim head gaskets, intake gaskets, and the correct thick black pan rail gaskets.
The red dash shows the correct finger tab on the gasket, the current available has this area completely covered by gasket.
ALSO the correct valve cover gasket is ALL CORK not salt and pepper.
There is tons of information on all of this on the NCRS website. It is searchable and viewable to non NCRS members.
madden (12-18-2018)
Old 12-18-2018, 04:41 PM
L16pilot L16pilot is offline
"The factory correct intake manifold gaskets are not available"
Zip Corvette offers a nice version with the tab.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
The Following 3 Users Say Thank You to L16pilot For This Useful Post:
BCreekDave (12-18-2018), firstgenaddict (12-19-2018), madden (12-18-2018)
Old 12-19-2018, 08:15 PM
I am glad to find them available.... I have one set left and I was not looking forward to paying through the nose the next time I needed them!
