Old 11-27-2021, 12:56 AM
all_about_cars's Avatar
all_about_cars all_about_cars is offline
Default Small block bolt kit
Complete small block bolt kit.
O marked head bolts
A marked oil drain plug
Two eng. lift hooks
3 cam sprocket L
Oil pump bolt. TR
Distributor hold down & bolt M
Crank pulley bolts 3 NAT
Balancer bolt & washer TR
T stat bolt & stud RSC
Water pump. RSC
Spark plug shields. RBW
Oil filter mount & bolts. RBW
Intake. 10 A & 2 RBW
Spark plug wire separators 4 piece
Plug wire stands 2 piece
Lower oil dipstick tube
Coolant plugs @ side of block
Battery cable supports @ oil pan
Fuel pump bolts anchor marked
Fuel pump plate & bolts E
Fuel pump push rod access @ front of block bolt SB
Oil pan bolts. 14 E & 4 B&H
Timing cover bolts. E
135.00 shipped lower 48 PayPal friends & family
Thanks Eddie
Attachments - The Supercar Registry 59008F69-555A-4BDD-B7E8-AD8BAA7699DC.jpg
Old 11-27-2021, 01:28 AM
the427king's Avatar
ill take it
No Fisher priced toys here
Old 11-27-2021, 01:30 AM
I will add it to your box. Thanks
