Old 06-27-2023, 02:18 AM
Arrowsmith's Avatar
Smile 1970 Nova Sleeper - 565 BBC "Plain Jane"
My Nova (aka "Plain Jane") is for sale. There's a detailed thread on the build here:
https://www.yenko.net/forum/showthread.php?t=174651
Basic car has 13,800 miles on it. Original panels, mostly original paint, original interior (carpet replaces rubber mat + driver side arm rest reupholstered). Car was rotisserie restored and looks just as nice underneath as it does on top. Heater delete. Radio Delete. Manual steering. Manual brakes (discs front; drums rear -- all new front and rear). Hurst roll control. Stainless lines. Stainless park brake cables.
Engine: 565 cubic inch big block Chevy. Dart 4.6-inch bore block, fully counterweighted Molnar 4.25-inch stroke crank, Molnar connecting rods, Mahle pistons (over all CR is just under 11:1), Mahle metric rings, Mahle pins, Brodix 345 cc BB3-Xtra heads, Brodix dual plane intake, Holley Ultra HP carburetor, Jesel 0.903-inch diameter (426 Hemi size) mechanical roller lifters, Bullet 0.765-inch lift custom roller cam, Trend double tapered pushrods, Jesel steel shaft rockers, Stef's aluminum oil pan, Melling billet oil pump with bottom pickup, custom Delco distributor, MSD 7AL2 ignition, MSD Coil, custom Summit-Packard wires, ATI Super Damper, Edelbrock aluminium water pump, ARP fasteners throughout+ more.
Transmission: ATI custom built TH400. Forward pattern manual valve body (allows for engine braking on the street), ATI custom Treemaster 10-inch converter, ATI SFI flex plate, Precision Performance Shifter, Earl's stacked plate transmission cooler, Earl's -6 AN lines.
Driveshaft: Mark Williams 7075 aluminum with billet end yokes. 1350 Spicer universal joints.
Rear End: Mark Williams custom built 12 bolt. Uses KTRE (now DTS) style large bore, large cap case, 35 spline Detroit Locker, 35 spline Mark Williams Pro Street axles, Mark Williams circle track style housing ends (with seals), 3.73:1 gears, billet yoke.
Exhaust: Lemons 2-25-inch headers with slip on tubes. 4-inch collectors. Headers have been black Cerakoted. Hooker 3-inch stainless steel exhaust with "X" pipe and turn outs after the stainless mufflers.
Fuel System: Custom fabbed with new tank. Holley Hydramat inside the the tank. -10 AN (5/8-inch) fuel feed lines, -8AN fuel return lines, -8AN fuel tank vent. Lines outside the tank are Earl's. Weldon Electric fuel pump, Weldon Regulator.
Cooling System: DeWitt's aluminum rad (coated black), OEM style pulleys, 396 rad support, 396 shroud, 396 fan, 396 style hoses. Heater delete.
Gauges: AutoMeter Monster tach, AutoMeter mechanical oil pressure, AutoMeter electric stepper motor temperature gauge.
Rolling stock: 15X8 custom wheels at the rear; 15X6 OEM wheels on the front. M&H Racemaster drag radials.
Suspension: Frame rails have been tied (frame connectors). Front springs are custom. Rears are split Mono Leaf from Calvert Racing. Traction bars are Smith Racecraft Assassin bars. Shocks are double adjustable AFCO's. Front A-arms are Detroit Speed. All of the steering and suspension components are new.
I'm I missed things -- there's certainly a lot more, but the build thread can provide more details. In case you didn't see it, the car recently won Best Street Machine at a large local indoor car show.
The car runs great. It's easy enough to drive, but honestly, it's quick on the throttle and it definitely gets your attention immediately when on the gas! It will send shivers down your spine...
Here's a video walk around of the car running:
https://youtu.be/uiXzeQ-IP2c
And here are some images of it:
[img]
http://i.imgur.com/AjWu1B3h.jpg[/img]
I'm in Saskatchewan, Canada (north of North Dakota/Montana). TFX Transport can pick the car up here, clear customs for you (no duty or taxes) and drop it off at your door. I can help with logistics, but I'm not transporting the car. FYI, TFX is a regular transport company for major US collector car auctions.
If you want an uber-cool, bad to the bone, absolutely Mint Nova, this is it. I have touched pretty much every nut, bolt and washer on this car. If you have any questions or need photos of anything else, feel free to contact me.
Price is $89,500 US dollars (Firm + No Trades). It will cost more than this to duplicate the car. The car is stunning in person and speaks for itself.
The Following 9 Users Say Thank You to Arrowsmith For This Useful Post:
69Z11Pacer396 (06-27-2023), big gear head (06-27-2023), BJCHEV396 (06-27-2023), dykstra (06-27-2023), L78_Nova (07-19-2023), SS427 (06-27-2023), Tenney (06-27-2023), Xplantdad (06-27-2023), Zman1969 (02-29-2024)
Old 06-27-2023, 02:21 AM
Lynn Lynn is online now
After all that hard work, I would have a hard time letting go.
Good Luck.
Arrowsmith (06-27-2023), dustinm (06-27-2023)
Old 06-27-2023, 02:23 AM
Arrowsmith's Avatar
Smile
Good Luck.
I am having a hard time letting it go. Car is off the chain in person and crazy fun to drive...if I pay attention!
Old 06-27-2023, 07:20 AM
cruiserofland's Avatar
cruiserofland cruiserofland is online now
Looks like a total blast - beautiful car and good luck with the sale
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
The Following User Says Thank You to cruiserofland For This Useful Post:
Old 06-27-2023, 10:57 AM
CamaroNOS CamaroNOS is offline
What a killer car. It will make somebody super happy, how can it not?
Good luck with the sale Wayne.
So what's next.......?
Paul
The Following User Says Thank You to CamaroNOS For This Useful Post:
Old 06-27-2023, 01:17 PM
Arrowsmith's Avatar
Thumbs up
Paul
Thanks Paul. I'm sure it will make someone extremely happy! What's next? There's a super nice car I'm looking at and I think I just might devote some "love" to my '56 Mercury pickup truck project (only in Canada...eh?....L-O-L).
The Following User Says Thank You to Arrowsmith For This Useful Post:
Old 06-27-2023, 01:15 PM
Arrowsmith's Avatar
Thumbs up
Thanks man...It is a total rush! Even starting it! Cold start is basically two pumps on the pedal and it fires (maybe more like "explodes to life") immediately.
Old 06-27-2023, 12:31 PM
TimG TimG is offline
Wow, what a beast of a car. The Nova body style is beautiful.
Old 06-27-2023, 01:18 PM
Arrowsmith's Avatar
Thumbs up
Thanks Tim! I appreciate it!
Old 06-27-2023, 01:35 PM
ls6owner ls6owner is offline
Great car Wayne! Good luck with the sale.
Oliver
Happiness is having Chevelles, Novas, and Mustangs in the garage, and a wife that is OK with it all!
The Following User Says Thank You to ls6owner For This Useful Post:
