Old 11-19-2018, 08:22 PM
lbnaz lbnaz is offline
Default GM 12 Bolt Gears
Anyone ever pull out or hear of a set of gears and posi removed from a 69 camaro 12 bolt and only the pinion is stamped GM not the ring. I have a set of 373 just removed from a 69 rearend like that. The pinion has 2-69 and part number 3862534 but nothing stamped on the ring. There is some white ink stamped markings on it that's all. I haven't taken it off the Eaton 3 series posi yet is it possible to be stamped on that side. Larry.
Attachments - The Supercar Registry IMG_4337.JPG IMG_4336.JPG IMG_4335.JPG IMG_4334.JPG
Old 11-20-2018, 02:08 AM
I've had GM gears that had the ring gear stamped on the mating surface. The numbers could not be seen until the gear was removed.
Old 11-20-2018, 10:30 PM
Good call "big gear head" I pulled the ring off and sure enough its stamped. I had thought of it but only got that far. Thanks for the suggestion. Larry
