Old 07-08-2022, 04:51 PM
Gonzo1717 Gonzo1717 is offline
Default B28 Vacuum advance can
Looking for a new/nos “B28” vacuum advance can. These were listed under several different part numbers, most commonly known is the VC1810.
Pic for reference.
Thanks!
Attachments - The Supercar Registry thumbnail.jpg IMG_4191.jpg b28.jpg 9E3D9E66-DD42-4866-AB6D-B9900DB58EED.jpeg
Old 07-09-2022, 12:48 AM
napa68 napa68 is offline
If you are looking for a correct specification can, use this......
https://www.corvettecentral.com/c2-6...5%26count%3d17
Old 07-09-2022, 03:49 PM
This can is fully deployed at 8hg like the B28?
Old 07-10-2022, 11:17 AM
Yes, I had checked it before installing. I'll add to that, I checked on the part number located on the box (as CC is buying it from someone else) and it was available from Rock Auto. I ordered a couple more just to have as I tend to work on these cars. Those did NOT deploy at 8". Just the one from CC
Tim
Old 07-10-2022, 02:33 PM
Tim, thank you for the info. I went ahead and ordered one. I ordered a WVE 4V1053 from RockAuto, which they lost as a replacement for a B28 and it does not fully deploy until 13hg.
What part number did you purchase from RockAuto?
Old 07-10-2022, 02:39 PM
Cannot remember.....
Old 07-15-2022, 07:46 PM
Zman1969 Zman1969 is offline
I have a B28 still in box I grabbed before they became extinct if your still looking
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 07-15-2022, 08:37 PM
Here's a couple good reads on the Vac can subject with cross references if you were not aware:
https://www.crankshaftcoalition.com/...ance_Specs.pdf
https://www.corvetteforum.com/forums...post1590683061
Owned since 1978 - First Car
The Following 2 Users Say Thank You to BCreekDave For This Useful Post:
169indy (07-17-2022), Gonzo1717 (07-16-2022)
Old 07-16-2022, 09:26 PM
PM sent
Old 05-22-2023, 03:16 PM
169indy's Avatar
169indy 169indy is offline
Default Info from WELLS
[email protected]
Tech Data on 4V1053 avail via Rockauto
69 Los Z11
68 SS/RS 396/325
68 Los Z28
