Old 01-27-2022, 12:46 PM
MosportGreen66's Avatar
This a great thread Bill. Congrats on another wonderful Chevelle project... told you this would win the forum over
The Following 2 Users Say Thank You to MosportGreen66 For This Useful Post:
60sStuff (02-03-2022), 67since67 (02-04-2022)
  #32
Old 01-29-2022, 03:39 AM
67since67's Avatar
Never doubted you Dan, and thank you!
Jumping to real time without giving too much away it was a good day today!
The rear power window operated but was a bit sluggish. Since it had to be removed to access tailgate trim fasteners it's time to freshen up. The regulator it self required only a light cleaning and lube, but the motor was the crustiest mess I've encountered on the car. Fortunately it was clean on the inside.
I disassembled, blasted and painted the motor housing. After polishing the armature and brushes, lubed, reassembled and adjusted the motor and gear box assy. Reinstalled and the window now buzzes up and down like new. Lubed latches etc while there also.
The Following 10 Users Say Thank You to 67since67 For This Useful Post:
69M22Z (01-29-2022), cook_dw (02-01-2022), Damien (03-22-2022), dykstra (03-06-2022), grantprix (02-23-2022), L78_Nova (01-29-2022), MosportGreen66 (01-29-2022), olredalert (01-29-2022), RPOLS3 (01-29-2022), Xplantdad (01-29-2022)
  #33
Old 01-29-2022, 04:06 AM
67since67's Avatar
To round out the good day my new neighbor and the local A/C wizard came by to bring the A/C to life. Thirty years ago the A/C got me home from CA with two cans of R-12, but hadn't ran since.
Duane brought along a new Delco dryer (he knows me well!) with a Made In China sticker on it I had set up with two 25' flex hoses to pipe exhaust outside (7 degrees) while running in the shop (70 degrees).
My cousin gave me a full R-12 canister a few years ago because it was obsolete for his farm equipment.
After evacuation held steady, time for a charge. Soo, I learned that the A/C control switch isn't sending power to the A/C clutch, worry about that later, jumper the clutch and away we go! The POA valve was a little stubborn but with a few light taps and a little patience with oil circulation, it was blowing 40 degrees a standstill idle.
A good day indeed!!
The Following 13 Users Say Thank You to 67since67 For This Useful Post:
60sStuff (02-03-2022), 69M22Z (01-29-2022), 72-SS-L48 (02-22-2022), cook_dw (02-01-2022), Damien (03-22-2022), dykstra (03-06-2022), grantprix (02-23-2022), L78_Nova (01-29-2022), MosportGreen66 (01-29-2022), olredalert (01-29-2022), RPOLS3 (01-29-2022), scuncio (01-29-2022), Xplantdad (01-29-2022)
  #34
Old 01-29-2022, 02:08 PM
----Bill,,,Gave me a big chuckle when I saw that window motor. Looks good now. Congrats on the AC!.....Bill S
  #35
Old 01-29-2022, 02:26 PM
Awesome! And Love those real paint valve covers peaking through too
The Following User Says Thank You to MosportGreen66 For This Useful Post:
  #36
Old 01-29-2022, 04:46 PM
67since67's Avatar
Thanks Bill! The rest of the car screams high desert 15% humidity, so why did that motor look like it went down on the Titanic??
Old 01-29-2022, 04:48 PM
67since67's Avatar
Thanks Dan, lots of nice finishes were hidden under a half Century of grease and grime!
Old 01-29-2022, 04:49 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Bill, the early AC systems pull the full clutch load across the switch. Common for the switch to arc and foul up. Best to install a relay to take the load of the switch.. I did this on my 67 Chevelle and 68 Acadian and it fixed my issue. Learned this troubleshooting on my 68 Acadian... installed an NOS switch and only got about a dozen uses before it fouled out. Been fine since adding the relay.
NICE to have R12 !!
Awesome job on the wagon!!
70 Chevelle SS-454 LS-5 M-22
  #39
Old 01-29-2022, 07:38 PM
WILMASBOYL78's Avatar
WILMASBOYL78 WILMASBOYL78 is online now
Default 67...
This thread just keeps getting better...really enjoying the process.
Keep it coming
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
  #40
Old 01-29-2022, 09:37 PM
luzl78 luzl78 is offline
I love that it’s not getting painted and you’re keeping the patina.
The Following 2 Users Say Thank You to luzl78 For This Useful Post:
