Old 07-17-2017, 07:00 PM
BillD BillD is offline
Default Sound deadener
I am looking to duplicate the look of original sound deadener/undercoating that was sprayed inside the quarter panels inside the trunk. The original stuff has a very thick coarse like appearance. I have tried some spray on undercoating stuff which doesn't come close to the look I'm after. Does anyone have any ideas of what to use to get is close to original as possible? Thanks for any ideas anyone might have
1966 Chevelle SS396 LS6 M22
Old 07-18-2017, 12:28 PM
I found this stuff which I think is what I need. Posting it in case anyone else may need it or if anyone knows there is something else. Thanks.
http://www.3m.com/3M/en_US/company-u...3241345&rt=rud
Old 07-18-2017, 12:33 PM
That's the stuff Bill. You will need the gun to apply it.
BillD (07-19-2017)
Old 07-18-2017, 12:54 PM
I have the same issue with a car that was undercoated at the dealer and needs a couple areas re-applied. The original stuff was asphalt based I think, so I was considering trying some driveway sealer, applied by patting it with a sponge to get a lumpy coating.
Verne
The Following User Says Thank You to Verne_Frantz For This Useful Post:
BillD (07-19-2017)
Old 07-19-2017, 12:43 AM
Lynn and Verne,
Thanks for your help with this. I am going to order the 3M stuff. I kind of like the driveway sealer idea but I am afraid it will bleed through the paint. Touching up under coating under the car might just work with the driveway sealer.
Of course I just saw the thread on the Berlage trunk paint which I was not intending to do but I think I will also give that a try.
Old 07-19-2017, 05:46 AM
Vern I have used asphalt based roof patching material. Comes in a one gallon size at Lowes or Home Depot.
Verne_Frantz (07-19-2017)
Old 07-19-2017, 04:48 PM
That sounds like it's worth a try. This is what I'm trying to duplicate. The dealer really shot everything in site with this stuff.
Verne
Name:  Trunk well undercoating.sm.jpg
