This is a GM ZZ 1 crate engine,new it was rated at 355hp and 400flbs. of torque,this engine was new out of the crate and had about 10k on it,the rings got washed out in it due to a faulty fuel system, it has just been rebuilt, the short block has done been put togather, it has been bored .030,its has all new bearings thru out and a new melling oil pump,the alum. heads also have just been done with some of the valves replaced as needed, new seals,the intake is cleaned and ready to install as is valve cover,oil pan,blancer,front cover,all new plugs have been installed in the block,gm hei dist. is also included.everything is here for the engine it just needs to be built from the short block up, engine can be shipped from 31602 asking 2000obo plus the shipping,,i can be contacted at
[email protected] or 904-349-6954,, thanks Frank
