Old 03-04-2022, 02:10 PM
mhm1966 mhm1966 is offline
Anybody using Shell Rotella which has a decent amount of zinc.
Old 03-04-2022, 02:38 PM
I use Penn Grade One, High Performance Oil 10W-30 Partial Synthetic high zinc. The original green oil.
The Following User Says Thank You to L72Biscayne For This Useful Post:
camarojoe (03-06-2022)
  #23
Old 03-04-2022, 05:36 PM
markjohnson's Avatar
Rotella eventually lost its Zinc too and is longer an option.
The Following User Says Thank You to markjohnson For This Useful Post:
mhm1966 (03-04-2022)
  #24
Old 03-04-2022, 09:55 PM
RPO LS7 RPO LS7 is offline
https://drivenracingoil.com/i-304978...t-rod-oil.html
John
Old 03-04-2022, 11:14 PM
RALLY RALLY is offline
VR1 Valvoline 10W30 oil for classic muscle cars. Enough zinc to protect camshaft. Might even try the Mercury 10W30 4 Stroke marine oil. Engineer i know said this oil has even less zinc then the VR1 Valvoline 10W30 oil and the Mercury out performed the VR1 in testing. Engineer told me to much zinc can actually cause wear in a engine.
The Following User Says Thank You to RALLY For This Useful Post:
ruralrte66 (03-05-2022)
  #26
Old 03-05-2022, 01:51 AM
1971ls6's Avatar
1971ls6 1971ls6 is offline
51060 or 51061 are the long ones, the 61 has the anti drain back valve
Old 03-05-2022, 04:27 AM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
So, I have a question... I'm reading that synthetic isn't highly thought of for this application, but that VR1 is... I don't believe that both comments have come from the same members but I did want to call this out and open a discussion on VR-1 being synthetic... thoughts?
Old 03-05-2022, 12:15 PM
napa68 napa68 is offline
Unfortunately, these oil discussions get pounded to death. The Brad Penn is what I use. It was suggested by the engine builder I use, as well as others that I have befriended and respect.
Haven't lost a flat tappet camshaft yet
Tim
  #29
Old 03-05-2022, 03:38 PM
Steve Shauger's Avatar
Administrator
I use Brad Penn or Joe Gibb.
www.yenko.net
www.vintagecertification.com
Old 03-05-2022, 04:13 PM
X77Z28MP X77Z28MP is offline
Not trying to change this discussion. But any oil recommendations for a stock rebuilt 69Z survivor. thanks
69Z X77 03D Lamans Blue
