Old 04-05-2022, 09:37 PM
nugeusa1's Avatar
nugeusa1 nugeusa1 is offline
Default L78 69 camaro block usage info needed
I have a 1969 l78 camaro that im trying to get back together. I have the POP and the engine assembly date was 1116 JD . I have the born with trans and rear but so far i havent found the original engine or block. Would the correct block for a 11C car be a 440 or a 272 ? Im going to build something to get it back on the road but it wont be correct because im adding aluminum heads but id like to put the correct casting block in anyway. Hopefully some day ill find the born with block , its a local car but still a longshot. Thanks Greg
Old 04-09-2022, 03:41 AM
the427king's Avatar
I have a sept 68 JJ stamped block that is a june 68 440 casting
No Fisher priced toys here
Old 04-14-2022, 01:16 AM
ssl78 ssl78 is offline
I had a 11C L78 Camaro engine was a 272 block build date was T1028JD Block cast date was I288
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
