Old 11-23-2018, 10:30 PM
Default COPO Eaton Posi
This is more of a question. Is this correct or does this guy not know what he has? What is the F4J code?
https://www.ebay.ca/itm/GM-Chevy-69-...4:pf:0&vxp=mtr
Old 11-24-2018, 12:40 PM
69 Post Sedan's Avatar
I’m not sure if it’s real.....if it was, you’d think he’d show everything disassembled, displaying all the internal parts as they are different than a standard unit.
F4J is the date code. F=June, 4=4th and J=1969.
Kurt
1968 Schwinn Orange Krate Original Paint
1970 Schwinn 3-Speed Deluxe Original Paint
The Following User Says Thank You to 69 Post Sedan For This Useful Post:
big gear head (11-24-2018)
Old 11-24-2018, 01:51 PM
Thanks. I sent him a message asking how many teeth are on the axle gears. He is supposed to be checking it. Am I correct in thinking that the COPO unit has 16 teeth on the axle gears?
Old 11-24-2018, 03:25 PM
----Rosebush is a well known guy around these parts. I don't remember hearing anything negative about his operation...….Bill S
Old 11-24-2018, 06:26 PM
m22mike's Avatar
m22mike m22mike is offline
The springs pictured I do not believe are COPO springs.
As far as the casting number, ALL 4 series standard or COPO used the same casting #.
The PN is different but not on the carrier.
The side gears for COPO are 16 teeth vs 18 on a standard 12 bolt.
It does kind of look like this unit has 16 tooth side gears, but you can not tell by that picture for sure.
And if it was a BE/KQ carrier, good luck finding the parts needed to make it complete. JMO
Mike
Old 11-25-2018, 03:41 AM
He sent me a reply and said that it does have 16 tooth axle gears, so I'm guessing that it actually is a COPO unit. I think these had 800 pound springs, not the green 200 pound springs.
Old 11-26-2018, 01:59 AM
I believe that it should also have the round plates, not the oval ones. Again, more pictures of it disassembled would be beneficial to the seller and the buyer.
I also agree that Rosebush is a reputable seller.
Kurt
