outdoor car cover recommendation
Hey guys. I'm about to purchase an outdoor car cover to cover up my car while I get funds together to finish off the paint, etc. The car is in AZ, so it needs to be good enough to stand up to the sun and not disintegrate in a month when a monsoon hits, which is what happens to the cheap covers generally found on eBay.
I'd like to keep the cost under $200 for it, if possible. Any recommendations? Thanks |
Re: outdoor car cover recommendation
My advice...rent a garage or storage unit...the benefit is truly worth the expense...you will get the investment back when it comes time to work on the car...
wilma
That sadly isn't going to happen, so I'm left with a cover.
I bought a Covercraft Sunbrella for my Dodge Dakota when I moved here. The cover held up OK for two years of usage, but it lost it's rain repellent after one year. However, it never tore.
Something to consider with outdoor cover use here in AZ. The wind/breeze will blow dust under the cover and the seams will catch it and scratch your paint wherever a seam or tight fit is. It all buffs out, but still an inconvenience. I have since stored the Sunbrella and now I put sunshades in the windows of the Dakota. I also have a part-time shady place in the yard to park it in. Either way, the paint may receive some sort of damage whether covered or uncovered. That's the reality here in the valley. BTW, if you want a cover that is too big for your Nova, mine is available, but needs to be laundered.
Rick 1966 Chevy Caprice 427-390 2012 Chevy Camaro RS Convertible] |
Thanks. I'll have to check that out. Mainly, I'd like to keep the rain off/out of the car so it doesn't build up. I don't have to worry about scratching surfaces. Once it is painted, I believe I'll be garaging the car at that point. Right now, the car is in primer and is pretty much ready for paint. The only thing preventing it from getting paint is my wallet. I hope to have the money together by the end of the year, so I have about 9-10 more months to go. Just wanted to protect it until then. It's also why I don't want to spend a ton of money on the cover.
Although at $545 for a '69 Biscayne, I don't think I'll be getting a Sunbrella.
I would recommend getting a "breathable" one. This will prevent moisture from building up between your car and the cover. I can't say which brand is the best. Classic Industries in Huntington Beach,CA has ones for outdoor use from $119.99 to $194.99.
Have you checked into those car "bags"? No experience with them and others could chime in and say whether they are worth it or if they are junk, but just a thought.
1968 Camaro Ex-ISCA Show Car John 10:30 |
OK, thanks. I'll check them out.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: markinnaples</div><div class="ubbcode-body">Have you checked into those car "bags"? No experience with them and others could chime in and say whether they are worth it or if they are junk, but just a thought. </div></div>
You know, no, I haven't. I wonder if they'd hold up to the sun. Basically this thing needs to make it through a summer (a lot of hot sun, and then monsoons). |
