Old 06-08-2020, 02:42 PM
subyman99 subyman99 is offline
Default Holley 4346 question
Hey guys, I’m battling an issue on my yenko. It has a really bad dead spot when lightly on the throttle. And if I step on it hard it will hesitate for a second then take off. I’ve adjusted and replaced accel pump with no change.
Does anyone know what number squirted should be on the 4346 Holley? Or have any suggestions ?
Thanks!
1967 Z28 survivor Black original drivetrain
1968 Z28 survivor white 40k miles
1969 Z28 survivor Rally Green 60k miles
1969 Z28 survivor Rally Green 20k miles
1969 Yenko Camaro Lemans Blue -muscatell sold new, second to last yenko made
1969 Berger copo original paint 240 miles
Lots of 67-72 Chevrolet trucks
Old 06-08-2020, 04:24 PM
ssl78 ssl78 is offline
With the car not running and looking down the carb when you give it gas does the accelerator pump squirt right away, or is there a slight pause?
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 06-08-2020, 04:42 PM
Have you checked the ignition timing? Retarded timing will cause a hesitation.
Old 06-08-2020, 05:33 PM
Check timing and rev it up with the vacuum advance hooked up to make sure it is working.
Make sure no vacuum leaks. Clean the idle and main air bleeds with some carb cleaner, especially if it has been sitting. I use a 31 squirter in my small block mild cam with headers Corvette.
Old 06-09-2020, 01:32 AM
Steve Shauger's Avatar
Administrator
Another possibility is your primary power valve may be opening too soon causing the hesitation. When did this start happening? You may need to go down a # or two. It could be what other suggest. Goodluck......
www.yenko.net
www.vintagecertification.com
Old 06-09-2020, 03:30 AM
To answer your initial question, the original squirter was .025.
You can go here, then save it as a pdf and keep it on your computer for quick reference.
https://documents.holley.com/techlib...al_listing.pdf
Old 06-10-2020, 12:49 AM
ban617 ban617 is offline
Maybe the squirter size
Old 06-10-2020, 06:46 PM
WILMASBOYL78's Avatar
Post 4346 issue...
Call Eric Jackson...
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
