Full Concours restored original front end suspension Hardware kits
All hardware are factory original assembly line installed pieces. No aftermarket pieces. All period correct head markings and finishes. Kits will be made specific to year and body.
The following is a breakdown of applications in a typical kit: 1. Front sway bar bushings retainer to frame bolts 2. Lower a arm mounting bolt 3. Upper a arm bushing retainer bolts 4. Upper a arm to frame studs and nuts 5. Steering box mounting bolts 6. Idler arm mounting bolts 7. Front shock mounting bolts and nuts 8. Back drive and cross shaft to frame mounting bolts 9. Sway bar bushing end play clamp mounting bolts 10. Tie rod end clamp bolts and nuts All hardware is restored to concourse level quality. We start out with original pieces which are chemically cleaned to prep for the plating process . Each is then visually inspected to insure there is no pitting, rounded corners or stripped threads. Any pieces that don't meet these standards are discarded. From there each piece is plated as called for per factory specifications. Kits are $375 plus $15 to fully insure and ship to the lower 48 via Pay pal friends and family. Kits will be made for specific applications such as: 67-69 F-body Camaro/Firebird 68-72 Nova 65-69 A-body Chevelle GTO 442 70-72 F-body Camaro/Firebird 70-72 A-body Chevelle GTO 442 Kits will also be made for other applications upon request. Keep watching this thread as it will be updated with new kits regularly. |
Pics 1
Pics 2
This first kit was specifically made for 67 through 69 F body and 68 through 72 Nova. I can change a couple of bolts to fit a body 65 through 69 and also 70 through 72 F body and A body.
Sale price for the next week $300 shipped to the lower 48
Bump, sale still going on for the next week.
I just assembled several more kits, will sell them at the sale price of $300 each or if you purchased two kits it will be $500.
Been a few months time to bump this thread. $300 sale price still applies.
THANKS SYC!! |
