What overdrive unit for my diesel?
Now that the reality of $3/gal, soon to be $4/gal. diesel has set in, I want to install an aftermarket overdrive unit on my diesel. I've got an 05' Dodge 4wd 6spd Cummins diesel dually. I drive everywhere, sometimes towing as much as 15,000 lbs of equipment or my race trailer w/ car.
Who makes the most bulletproof unit? There is no reason that I can't at least drop 500 rpms on level ground at hiway speeds, and when it's empty, I want even more. Has anybody had much experience with the units that bolt on to the tail housing?
Steve H. industrial art collector |
Re: What overdrive unit for my diesel?
I know the Allison that they are putting in the Chevys' and Dodges' is great. I drove a Chevy (with the Allison) a year or two ago that was given to its owner by the NASCAR folks for the exhaust work he does for them. I hooked my trailer to it and took it for a test and it was outstanding. I now have a '04 PowerStroke but unfortunately no Allison (only on F-450 and higher). I would strongly recommend investigating into this Allison unit. PM me and let me know what you learn.
Good luck, Rich
L.Z. "...at this point in my life, every day is a Saturday". |
Rich, thanks for the lead, I'll check em' out. I was surprised at the number of different vendors that offered them, but I wondered if most weren't made by one or two manufacturers and just stamped with different name plates. Whatever I end up with is gonna get a workout.
After searching for the last month, I've decided to go with a unit called the "Auxillary Transmission" from a company called US Gear. The unit is rated to 35,000 lbs GVWR, and is available for GM, Ford, & my Dodge. They are available with an overdrive ratio of .80 or an underdrive of 1.25. The bad news, is that on my 4WD truck (maybe all trucks, I didn't care about the other applications) they mount between the transfer case and the transmission. Aside from the obvious modifications (driveshafts, linkage, ect. ect.), I will have to remove a little floor pan from my rear passenger area. On a Dodge, that will leave me one seat designated for children and midgets only.
The cost will be somewhere north of $4,000.00, but at 1,000-1,500 miles a week, it should pay itself off with in a year. If this works out, I'll start learning how to burn manure and Cheetos too, gotta do something fast, my fuel bill is eating into my racing budget.
Or, you could buy an '06 GM Duramax...they're getting a 6-speed Allison automatic now with a double overdrive I believe...
Check out the Gear Venders unit.It mounts after the transfer case.I've got one and it works great.You can also gear split with it.
"Knowledge is good" Emil Fabor 67 L/78 Camaro SS/RS H-H,1W,2LGSR,3SL,4K,5BY. (Sold) 70 L/78 Nova M-21,Black Cherry,Sandalwood Int. 09 Pontiac G8 GT Premium,Sport,Roof. Liquid Red. |
What kind of increase in fuel mileage should you expect with an overdrive unit?
PaulD '64 R-Code Mercury '62 421 SD Catalina '66 L72 Impala SS '66 R-Code Fairlane |
