Old 11-25-2022, 03:53 PM
WILMASBOYL78's Avatar
Post 68 Camaro...
Nice job on getting the front end pieces cleaned...looks great.
?? How does that Mark Ten unit work, I have seen these before, but not really up to speed on how they work.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
napa68 (11-25-2022)
  #262
Old 11-25-2022, 06:13 PM
TimG TimG is offline
That looks great, Tim.
napa68 (11-25-2022)
  #263
Old 11-25-2022, 06:37 PM
napa68 napa68 is offline
-wilma
It's a transistorized amplifier of sort. There was one on the car from way back. This one is installed as a dummy of you will. The car actually has a MSD box hidden under the dash.
Tim
The Following 3 Users Say Thank You to napa68 For This Useful Post:
69M22Z (11-26-2022), dykstra (11-26-2022), olredalert (11-25-2022)
  #264
Old 11-26-2022, 02:09 AM
dykstra's Avatar
dykstra dykstra is offline
Looks great Tim!!
Dave Dykstra
2013 Corvette Grand Sport 60th Anniversary
NCRS#66003
“Education is what you get when you read the fine print. Experience is what you get if you don’t.”-Pete Seeger
Dykstra Motorsports
Old 12-12-2022, 09:02 PM
Off to see the wizard tomorrow
The Following 13 Users Say Thank You to napa68 For This Useful Post:
1967Z28 (12-12-2022), 427 (01-04-2023), 69M22Z (12-13-2022), big gear head (12-13-2022), cook_dw (12-16-2022), Crush (12-12-2022), dykstra (12-12-2022), John (12-20-2022), juliosz (12-12-2022), L78M22Rag (12-16-2022), olredalert (12-12-2022), PeteLeathersac (12-13-2022), Too Many Projects (12-12-2022)
  #266
Old 12-12-2022, 10:13 PM
dykstra's Avatar
Awesome!! Can’t wait to hear the bad assery!!!!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
napa68 (12-12-2022)
  #267
Old 12-12-2022, 10:44 PM
I see you have your snow shovel with....just in case...
Next 3 days down here will be interesting for weather.
napa68 (12-12-2022)
  #268
Old 12-19-2022, 06:52 PM
cook_dw cook_dw is offline
Banned
I like this car a lot.
napa68 (12-19-2022)
  #269
Old 12-22-2022, 06:02 PM
The L88 is apart and all has held up well. The block, cylinder bores, pistons (TRW 12.5:1), crank journals all look good as does the dimple rods (bushed for floating pins). The ZL1 cam and lifters all look good, measured out to spec, and will be reused.
The only issue that was discovered is the flywheel was way out of balance (for whatever reason). That will get addressed and balanced with the pressure plate. I did notice there was a vibration above 5000 rpm. While it wasn't terrible, I felt it should be better. Glad we found a smoking gun there.
So, a simple hone job and hot tank. All new rings, bearings, and gaskets. We'll add the 842 aluminum heads I had redone earlier this year (for this little side project) in addition to another 163 intake (divider milled out).
Eric Jackson helped me source an old school Holley 4781 850DP. He should have that tomorrow to build a trick little carb specifically for this combination. I suspect by the end of January it should be on the dyno.
Merry Christmas everyone!
The Following 8 Users Say Thank You to napa68 For This Useful Post:
1967Z28 (12-22-2022), 69M22Z (12-22-2022), big gear head (12-22-2022), dykstra (12-22-2022), juliosz (12-22-2022), olredalert (12-22-2022), RPOLS3 (12-24-2022), Steve Shauger (12-22-2022)
  #270
Old 12-22-2022, 09:02 PM
dykstra's Avatar
Great to hear Tim!!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
