Old 02-07-2009, 04:10 AM
Default Re: lift hooks
SB--Flint
BB--Tonowanda
Tonawanda also built a # of small blocks.
Steve,
My question was specifically, were there any '69 DZ motors built at Tonawanda? If so, that might help to answer the question of the lift bracket differences. If not, then I'll go away and let you guys fight it out.
But I will add my common sense view. It doesn't make any sense for the engine plant (which had to hoist the engines onto racks for shipping) to require the vehicle assembly plants to remove 4 bolts, install 2 lift brackets and re-attach them just to get them off the pallet on their way to the chassis.
OK, now I'll shut up.
Verne
Old 02-07-2009, 04:55 AM
Jerry@CHP Jerry@CHP is offline
Banned
Here's another survivor engine bay taken about 15 years ago. Don't think this one has been fluffied up.
Jerry
Old 02-07-2009, 05:15 AM
Banned
Verne,
I have not seen any to date but I think that L. Christensen has. I have seen some 388 blocks used on the 302.
Jerry
Old 02-07-2009, 05:35 AM
sg1747 sg1747 is offline
wow,did i start this hole thing over engine hooks.
Old 02-07-2009, 05:36 AM
Steve Shauger's Avatar
Administrator
I have seen a handful of Tonowanda cast blocks( see comments below for clarification) built as DZ 302 engines. As a matter of fact Kenny P's green vintage certified Z28 was in fact a 388 block.
Let me clarify; 388 blocks are known to be cast at the Tonowanda plant. It is fairly common to have say L48 350/300hp assembled, and stamped TOXXX( Block cast and assembled in Tonowanda).
Now in the case 302 I have seen a handful with 388 blocks, however they are stamped VOXXX indicating they were assembled in Flint. So the question really is was the 388 block exclusively cast at Tonowanda (conventional wisdom)? If that is the case then the block was cast in Tonowanda and shipped to Flint for assembly (not sure that makes sense). Or another theory is that in fact the 388 block was cast at Flint in very, very small quantities, at a specific time period.
Verne to answer your question, I have not seen a DZ 302 with a Tonowanda assembly designation, so at this point I only believe they were built/assembled at the Flint plant.
If anyone has Tonowanda assembled DZ 302 please share the information and provide a picture of the stamping.
The attached photo is a 388 block, which are sans the plug in the front. Also notice the assembly /date starts with VO Flint assembly designation.
www.yenko.net
www.vintagecertification.com
Old 02-07-2009, 06:18 AM
farone farone is offline
Pics as promised..... This is a really cool survivor that was at Vettefest this past fall.
What do I know ????? I didn't write any books....
Old 02-07-2009, 06:19 AM
another
Old 02-07-2009, 06:20 AM
last one
Old 02-07-2009, 06:22 AM
same color as my friends 32,000 mile Z is.
Old 02-07-2009, 06:34 AM
I have seen a handful of Tonowanda built DZ 302 engines. As a matter of fact Kenny P's green vintage certified Z28 was in fact a 388 block.
Well, in that case gentlemen, instead of arguing over plain or painted lift hooks, you might make a list of which ones are Flint & which ones are Tonawanda. As I said, the order of assembly and paint was different at the two engine plants.
Verne
