Old 11-11-2018, 01:16 PM
Default 70 Nova Heater Box, Cowl Panel and Engine Harness
Being that there are many Yenko and L78 Nova guys here I thought I would ask if anyone has the following original parts available. I'm assuming these parts crossover multiple years and that the heater box is the same for Camaro?
Front Cowl Panel 68-72
Complete Heater Box 68-72 SBC
Engine Wiring Harness 4 Spd SBC (No Gauges)
Wiper Transmission 68-72
Wiper Arms & Blades
Let me know if you have any clean parts. Shipping to 59484 Montana. Thanks for looking.
Old 11-11-2018, 03:11 PM
ALLZS ALLZS is offline
I have a cowl panel from a 69 nova
The Following User Says Thank You to ALLZS For This Useful Post:
NorCam (11-11-2018)
Old 11-11-2018, 04:47 PM
bbbentley's Avatar
Originally Posted by nova7579 View Post
FYI wiper transmission is the same as 69 Camaro.
Brian
I believe the heater box & wiper arms/blades are same as 1st gen Canaro, as well
If the parts are same as Camaro, I believe I have everything you need less cowl panel and outer (engine compartment) heater box, unless you want a big block outer?
FULL OWNER HISTORY
The Following User Says Thank You to bbbentley For This Useful Post:
NorCam (11-11-2018)
Old 11-11-2018, 07:56 PM
I have the outer box and an NOS core. But need the complete inner assembly. I believe they are the same as Camaro as well. Wipers and arms are also the same if you have those too. I'll shoot you guys a PM when I get back from blowing snow off the driveway. Got 4" overnight. Ugggh.
Old 11-12-2018, 12:48 PM
bbbentley's Avatar
Brian
Can someone confirm / verify this? I cannot find a definitive answer.
FULL OWNER HISTORY
Old 11-12-2018, 02:24 PM
Woj's Avatar
Woj Woj is offline
I parted a 69 Nova a few years back and have the wiper assembly and heater box. I can send some pix Wednesday if interested..
The Following User Says Thank You to Woj For This Useful Post:
NorCam (11-13-2018)
Old 11-13-2018, 04:38 PM
Sent you a PM Phil. Thanks in advance
Old 11-13-2018, 05:45 PM
Man Graeme, I was going to tell you to forget about the heater as that looks cool and IS a weight savings, but then again, it can get down right nippy up in Canada .................................................. .................................................. ...................... during the summer months! ;>))
Old 11-14-2018, 03:27 AM
nova7579's Avatar
nova7579 nova7579 is offline
bbbentley and others.......sorry for the wrong information. They are not the same.
Brian
Old 11-14-2018, 11:56 AM
Yes it can be off sometimes Sam. For the most part summers are good here with 70-90 degree temps, but I've seen 4 seasons in one day here whether it be May, June or July. I took the 68 to a local show mid August of this year and when I rolled it out to fire it up, the temps were just a few degrees above freezing that morning. (Rocky Mountain weather is unpredictable at best)
As far as the heater assembly goes...just trying to add some weight to bring the front end down w/o cutting down the front springs. Fluids, intake and headers should add some weight and settle in down another inch or two.
Brian
Thank Brian...
