Old 11-12-2018, 06:39 PM
madden madden is offline
Default deuce LT1 valve cover restoration
hi
need help please with the correct way to restore my deuce LT1 valve covers
fro cleaning / striping/ and what finish to put on them?
thank you
chris
1970 citrus Yenko Nova
Attachments - The Supercar Registry valvecover_before.jpg valvecoverPrior2.jpg valvecoverfinish.jpg Valve Covers.jpg
Old 11-12-2018, 06:44 PM
YENKO DEUCE REGISTRY's Avatar
The factory finish was a 'dull lustre', while the NOS ones from GM are much shinier - if that's a word. I've learned that if you glass bead them they will lose all lustre. Some guys have had them tumbled in various media with mixed results - likely walnut shells or plastic media is best. Finally, Jerry McNeish offers a 're-skinning' service that has been well received. The rest of us simply buy the best original condition ones we can find and rub them out by hand....
Marlin
The Following User Says Thank You to YENKO DEUCE REGISTRY For This Useful Post:
madden (11-19-2018)
Old 11-12-2018, 07:27 PM
I blasted my thermostat housing with 100 grit sand and then tumbled it in ceramic media and it came out looking like new, or at least I think so.
Old 11-12-2018, 08:13 PM
Did mine by lightly blasting with low pressure glass beads then 0000 steel wool to put a light shine in the peaks of the fins to put a very light shine on the flat surfaces. Had to do it twice to get it where I wanted. The key is to not rough it too much in the blast cabinet. I used about 40 psi, just enough to pick up the media and stayed about 8 inches away from it. Just enough really to clean the surface and even out the surface.
I then followed up with the satin finish Ever-Brite to seal the pores and make them easy to keep clean.
Name:  Valve Covers.jpg
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
madden (11-19-2018)
Old 11-12-2018, 08:14 PM
I recently cleaned up the valve covers for my 71 LT1. I feel like they look right as far as the finish color etc.
I used organic PH neutral cleaner then used neverdull cotton wadding, however they were not too dirty when I started....
The FIRST PHOTO IS FINISHED
TWO SECOND PHOTOS ARE PRIOR TO CLEANING.
Old 11-12-2018, 10:49 PM
1971ls6's Avatar
1971ls6 1971ls6 is offline
Blast them and the steel wool is the best thing I have found other than jerry
The Following User Says Thank You to 1971ls6 For This Useful Post:
madden (11-19-2018)
Old 11-14-2018, 04:20 PM
thx guys
really appreciate the help
regards
chris
Old 11-14-2018, 06:55 PM
McCune McCune is online now
I used some walnut media in my blast cabinet, followed with steel wool. I think I could have used glass bead at low pressure with similar results.
The Following User Says Thank You to McCune For This Useful Post:
madden (11-19-2018)
Old 11-14-2018, 11:55 PM
cwc's Avatar
cwc cwc is offline
What grit walnut shell?
1967 SS427 4 speed triple black survivor-sold to a good home
1969 nova SS396 L78 4 speed triple black survivor
1970 camaro SS350 citrus green,Dad bought it new!
1968 chevelle ss396 L34 M21 KK rear all born with
1972 formula 400 M22
The Following User Says Thank You to cwc For This Useful Post:
madden (11-19-2018)
Old 11-15-2018, 01:14 AM
marxjunk marxjunk is offline
vapor hone..google it..the high end motor cycle guys use it on delicate parts..does amazing things on aluminum parts....has that luster everyone is looking for...
Mark
The Following User Says Thank You to marxjunk For This Useful Post:
madden (11-19-2018)
