#11
I emailed Muskegon Brakes as I too need my calipers sleeved . White post quoted over $300 a caliper last year hence why I waited. Muskegon quoted cost of Camaro caliper build to be:
$179.95 per caliper with o-ring seals or $129.95 if they use lip seals. Turnaround time is approx 4 weeks. That's bore, sleeve and test pressures. Survivor style no restoration (paint etc) "Payment will be collected when they're done and ready to come back to you." |
The Following User Says Thank You to cook_dw For This Useful Post: | ||
RPOLS3 (03-30-2023) |
#12
Was that for single piston or 4 piston calipers? Edit to add: I just talked to Muskegon. They quoted me $179.95. If they send them to Lonestar, I wonder why Lonestar quoted me $219.95. I guess I'll be sending them to Muskegon.
1968 Beaumont SD396 Last edited by 427.060; 03-30-2023 at 07:40 PM. |
#13
4 piston.
#14
I used Lonestar for my 70 LT-1 Corvette brakes. No issues.
#15
Mike Gibbons say dot 4 when he does brake parts.....Joe
#17
The only advantage to Dot5 is it won't eat paint if you spill.
#18
My 67 had DOT 5 in it since the early 1980s. The restoration was started in the late 70s and the original owner told me Dow Chemical gave him a couple gallons of DOT 5 to try. Amazingly, when I disassembled the calipers, wheel cylinders and master, all were spotlessly clean and attracted no rust, bores were all perfect as well. I have heard that this is another benefit of DOT 5.
#19
I like Mike Gibbons. A great guy and easy to deal with. Had several parts done by him.
The Following User Says Thank You to Salvatore For This Useful Post: | ||
X66 714 (03-31-2023) |
#20
