Old 04-20-2021, 08:05 PM
mssl72's Avatar
mssl72 mssl72 is offline
Originally Posted by dykstra View Post
My expectation exceeds my skill set.
I love that too!!!
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 04-20-2021, 08:56 PM
L16pilot L16pilot is offline
^^^exactly what Dave says...and I'd like to add to that just a little. I am not a professional painter, but have some good friends that are and that have guided me through when I had questions or needed advice. As a hobby painter, to me an important element that cannot be overlooked is simple preparation. I make myself a checklist step-by-step from the time I step foot in the shop to when I'm done and lay down the gun....even laying out mixing ratios and between coat times for easy reference. For me at least, because I do not do not paint on a regular basis, that once you start, the stress and anxiety can creep in and small steps in the process can be overlooked.
Dave is spot on about taping his suit and the potential for sweat or moisture to drip at the worst possible time. To add to this, as you practice, try spraying with the hose over your shoulder or wrapped behind your waist and held with your non-gun hand...helps keep the hose from contacting the surface....especially when reaching across hoods and roofs.
Good luck!
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
Old 04-22-2021, 02:29 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Some of the best tips I ever got from a painter; Dry run with the gun and hose (know your path and obstacles) & After mixing and before you spray... Slow Down... start calmly.
70 Chevelle SS-454 LS-5 M-22
