L78 intake
I have an L78 intake originally from 68 camaro,has repair in 1 bolt area and a damaged bolt hole at thermostat housing.
Any comments, if this is worth trying to repair or should it be discarded?
Bernard |
Re: L78 intake
I think any factory aluminum intake is worth saving. Many not be usable for high end applications but there is likely a home for any usable intake.
Jason |
Re: L78 intake
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SuperNovaSS</div><div class="ubbcode-body">I think any factory aluminum intake is worth saving. Many not be usable for high end applications but there is likely a home for any usable intake.
Jason </div></div> Thanks for the response Jason.
Bernard |
Re: L78 intake
I agree - plus I would also add.....that I would much rather have a repaired original over a fake snowflake intake [img]<<GRAEMLIN_URL>>/thumbsdown.gif[/img]
69 300 Deluxe Post Sedan Frost Green 69 SS396 300 Deluxe Post Sedan Lemans Blue SOLD 70 Buick Skylark Post Sedan Gulfstream Blue 70 Buick Skylark Post Sedan Burnished Saddle http://m.youtube.com/watch?v=PM3DE8qI2NY https://m.youtube.com/watch?v=Yn4xEmGypUw |
Re: L78 intake
Saving this intake is a good idea. You can have it welded by a professional
aluminium welder. then depending on the damage threads, you can carefully re tap the holes. on the intake bolt holes you can work the extra access weld by a rotary file If you were close to me I would help you return this intake to almost orig cond Go for it PJ |
Re: L78 intake
Jerry M.Does a good job with intakes so does Jeff Dotterer.
"Knowledge is good" Emil Fabor 67 L/78 Camaro SS/RS H-H,1W,2LGSR,3SL,4K,5BY. (Sold) 70 L/78 Nova M-21,Black Cherry,Sandalwood Int. 09 Pontiac G8 GT Premium,Sport,Roof. Liquid Red. |
