Old 10-13-2020, 11:54 PM
cdn454LS6 cdn454LS6 is offline
Default 12 Bolt Posi GM Eaton 3 Series Unit //3.31 Gears Chevelle Camaro
12 Bolt GM Eaton 3 series Posi Unit with 3.31 Gears
3 Series 30 spline Posi Unit EDB 30140
The ring has nothing stamped on it.
The Pinion gear has 3862693 13-43 GM
stamped on it.
This 3 series unit and gears were removed from my
1970 chevelle LS6 with documented 41,000 miles
in the registry.
These were factory gears that were original to the car.
I installed a set of 410's instead. The car is long sold.
Everything was working fine when removed and no damage.
Looking back I should have just left the original gears in and
never removed them.
All pieces are there for a complete switch over.
$500 usd + shipping
Attachments - The Supercar Registry IMG_4021.jpg IMG_4020.jpg IMG_4019.jpg IMG_4018.jpg
Old 10-14-2020, 01:47 AM
The ring gear will be marked on the mating surface. You will have to remove it to find the markings.
Old 10-14-2020, 03:39 PM
XXXGoldL34M20's Avatar
Ken PM Sent
Old 10-15-2020, 04:04 AM
SOLD Thanks sYc
