Old 01-02-2019, 11:26 AM
Default W30 power seat repair
The above on my car appears to be jammed. There is power to the switch but I can't get any movement out of the seat. Any idea of next steps for this?
Thanks
Lawrence
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle
Old 01-02-2019, 12:39 PM
Check for faulty Fuse, Ground, bad Wires, a bad Relay and last a bad motor.
You should get yourself a 1970 Cutlass / 442 Assembliy Manual.
Good luck,
Old 01-02-2019, 03:03 PM
----What Dan said, and then yank the whole seat and inspect carefully as stuff has a way of getting jammed in the tracks. Those motors are fairly robust......Bill S
Old 01-02-2019, 03:19 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
There is also a gearbox/solenoid bank which engage the required cable (depending on desired movement). These are very bad for sticking or not engaging due to old dried up grease/lubricant. They often need to be fully dismantled, cleaned and re-lubed to operate correctly.
70 Chevelle SS-454 LS-5 M-22
Old 01-03-2019, 12:02 AM
Just got the assembly manual so will dig into that.
Thanks guys
69 Z/28 RS
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle
Old 01-03-2019, 01:05 AM
70post 70post is offline
There's not anything in the assembly manual on the power seat track. MAY be some info in a Fisher Body manual but likely just some drawings or pics.
I just checked my '70 Olds Chassis Service manual and not a thing in there either.
Pull the thing out if you can get to the track bolts (after first checking for a bad ground or something more "obvious" with it still in place and w/power to the seat motor) and start checking, pulling parts, cleaning, re-lubing, etc. If it's never been messed with a thorough cleaning and relubing of the various parts is going to help any way.
Patton Glade
70Post Restorations
Austin, TX
Old 01-03-2019, 01:46 AM
Fisher Body Book has the power seat diagnosis contained in it.
Old 01-05-2019, 12:05 PM
Yep, my AIM is no help. I will start looking for obvious issues. Acts like it is just "stuck" since power it going to it. Will let you know.
James, thanks for the info. I don't have a Fisher Body Book
69 Z/28 RS
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle
Old 01-06-2019, 05:41 AM
mssl72's Avatar
mssl72 mssl72 is offline
This is exactly what I had to to do. The grease wasn't grease any more.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 01-13-2019, 02:04 AM
I have not gotten to work on this yet. Luckily the seat setting is fine for me. Will take a look soon. Thanks for the replies.
69 Z/28 RS
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle
